1 - 20 of 124 Posts
· Retired Moderator
Test set up:
2017 Spider Lusso
Automatic Transmission
EuroCompulsion Euro-Drive Lite-Dynamic Tune
EuroCompulsion V1 Air Intake
Home made muffler delete
Full tank of gas
Ambient Temp-75 F
Inlet Air Temperature 89-82 F
Traction Control Off
Car left in Drive letting it shift at 6250 rpm.
Top Down
Only me in the car(155 lbs)
Tire Air Pressure 29.1 PSI
Recording device-Ultra gauge OBDII instrument/use VSS for data collection
Flat asphalt road...as much as you can tell...
I made multiple runs. Without loading the torque converter produces the slowest 0-60 of 6.92 sec. This converter will not flash very high so that is why it is slow this way. You can load the converter up to around 2600-2700 rpm. This produced the fastest time of 6.40 seconds but also produced wheel spin out of the hole. I had multiple runs of 6.44 to 6.48 seconds. On a stickier surface I believe you may be able to load it a little more, possibly to almost 3000 rpm. With the top up, a cooler morning and a stickier surface a 6.0 or 5.9 could be possible. Manually shifting the automatic may also produce a faster time due the requirement of the transmission to make a shift from 2 to 3 right before 60 mph. My next runs will be made manually shifting the car. I will try to get out early in the morning to make some manual runs.
· Retired Moderator
So happy I'm not into numbers or performance mods. I just love driving whatever is in front of me.
I apologize for this post, and my disregard for .01 differences in stats.
I have put 2000 miles on my car in 7 weeks driving the mountain roads of Arizona not once worrying about the 0-60 time. ;) On another note...some people would like to know the performance of certain mods. I will do the best to provide some useful information in my spare time. Have a great day driving you Spider.
Test set up:
2017 Spider Lusso
Full tank of gas
Ambient Temp-75 F
Top Down
Thx for taking the time to post
Mike
Yes. Thank you Pure. Can I call you Pure?
Many of us are interested in how much improvement a certain device or combination of devices can provide. I have the same set up, except for the muffler delete. I noticed a bit more rumble out the back when I installed the EDL. Did you notice that or had you already deleted the muffler? Also, did you purchase a part online, or go to a muffler shop to delete your muffler?
· Retired Moderator
Pure is just fine. I already had the muffler delete on. I had it made by a local muffler shop. Some of these shops are really good at this type of stuff.
· Vendor
Good job. 6.4 is a pretty good time. There are no official 0-60 specs for the automatic as far as I can tell, but I think that's a full 1 second faster than stock. It's tough to tell because the numbers are effected by a lot of variables. TFL got about 8.7 in their "very unofficial" 0-60 test, but that was in San Diego, I assume in higher temperatures, and with two people in the car. They had a stick shift, but it doesn't look like they were shifting very fast :
sticky surface and lower temps and you just might.
I don't think it will with the Dynamic map, but maybe. It's worth trying. Shifting at 6250 with that map seems to work pretty well.
· Retired Moderator
Discussion Starter · #8 ·
Good job. 6.4 is a pretty good time. There are no official 0-60 specs for the automatic as far as I can tell, but I think that's a full 1 second faster than stock. It's tough to tell because the numbers are effected by a lot of variables. TFL got about 8.7 in their "very unofficial" 0-60 test, but that was in San Diego, I assume in higher temperatures, and with two people in the car. They had a stick shift, but it doesn't look like they were shifting very fast : https://www.youtube.com/watch?v=QZ3RkIzN8as
Not the horsepower up there between 6250-6500 that would make a difference in the times but maybe it will hit 60 before it shifts again if I go to 6500. It will be real close. Missing that extra shift could make a big difference. We will see.
· Vendor
Hmm, good point. Let us know. I would check myself, but my car is running a different map.
I think that makes sense. I'll have to try that. I was surprised that you were able to hold her still at the rpms you were using at launch. I have trouble keeping the brakes locked at 2000 rpms. Also, I was concerned about putting too much stress on the torque converter. Thoughts? Answers?
Reactions: PureAdrenaline
· Retired Moderator
Discussion Starter · #11 ·
Torque converter should be fine....but I wouldn't make a habit of it.;)
· Premium Member
Why are people so obsessed with 0-60 times? They are car abuse and not a great real world measure of performance anyway. And the 124 is a sports car not a drag racer. If you want to drag race you bought the wrong car.
· Vendor
I think obsessed is too strong a word. We are interested in all aspects of performance. Clearly if I was obsessed with 0-60 times, I wouldn't have bought a Fiat 124, or a Fiat 500L, or a Fiat 500 Abarth, or any of the other cars I own. This is just one aspect of performance, and it's the topic of this particular thread. :)
· Retired Moderator
Discussion Starter · #17 ·
I believe 0-60/62 is a real world measure of performance. That spec has been used for at least 50 years not only in the U.S. but around the world as a measure of performance. Porsche, Ferrari, Mercedes, BMW, Chevrolet, Mopar, Ford and almost every other manufacturer go to the trouble to test and publish these times for a reason. Now that being said...it is not the only measure. You also have handling(suspension/chassis/brakes) of the car. They all fit together to define a performance automobile. You can have the best suspension in the world under a chassis but if it take 18 seconds to get to 60...that's not real world performance. And vice-versa.
· Premium Member
0-60/62 is a "generally accepted" measure, but it's not a good one or a "real world" one. 80-120kph (50-75mph) would be a much more "real world" measure and much less susceptible to "variables". I've owned cars like a Renaultsport Megane that struggle to launch cleanly and can only muster 6 secs 0-62 that can keep a Boxster S honest 50-75. That's "real world" performance.
Reactions: Seagas and MotoPete
1 - 20 of 124 Posts
