1 - 14 of 14 Posts
· Super Moderator
4 is good 5 would of been better, lets see what Fiat can do.
The Mazda MX-5 just underwent Euro NCAP crash testing and it came away with a respectable 4 out of 5 stars.
Euro NCAP says that the Mazda performed well across all tests, lauding the MX-5's standard deployable hood for protecting pedestrians.
They did note that in the event of a frontal impact the drivers head may make contact with the steering wheel as the airbag didn't have enough pressure. They said dummy readings were good regardless. Chest protection in the event of a side impact is only rated as adequate, but lets be serious, you're buying a convertible and they inherently offer less protection.
Safety Assists are what kept the MX-5 from reaching 5/5. Mazda doesn't offer an autonomous braking system, leaving it with a 64% rating for Safety Assists.
The package seems fairly robust, should Fiat want that 5 star rating for the 124 Spider they'll only need to include autonomous braking.
Frontal crumple looks like it doesn't even reach the driver which is great but the side airbag leaves a large portion of your arm unprotected. Most likely will come out with a broken arm if you get hit on the side in the 124.
That looks pretty good for a 64mph and the full frontal crash looks even better. Your head will be sufficiently protected in a side collision but yea, looks like your shoulder area takes the brunt of it unless they install more air bags.
Interesting in that the front offset crash causes the rear fender just behind the door to crumple / distort. The new chassis that has more in line structure than before sure works - it transfers / spreads that energy across the entire car body!
In all honesty when you're driving a convertible you've already made the choice to be kept less 'safe' then normal...
Go back to post #1 and play the YouTube video. You can see in the second test (full frontal impact) the hood pops up about 6 inches to reduce pedestrian injuries. Again, at the end of the video, they show head impact with the raised hood and leg impact with the front urethane nose. I expect similar things from the Fiat 124 Spider. After all, they know what works on the Mazda ND.
Ace Orthopod
Not sure which of you guys works in Major Trauma Centre or is a Consultant Orthopaedic Surgeon - I am both - the right upper limb looks as well protected as in any side impact in a relatively small car. What matters are the lateral flexion injury to the cervical spine & lateral compression to the pelvis - they score high on the Injury Severity Score & matter - the car seems to perform as well as any without curtain airbags in both.
As in all cases prevention is paramount ! There is good visibility & it is likely to be driven by the experienced who drive well & are a good judge of speed & distance.
1 - 14 of 14 Posts
