I've upgraded almost all of my lighting to LEDs and thought I'd share my latest update, these LED DRL and turn signal lights. Straightforward install process, I just had to remove the wheel well liners and the panel under the engine to run the wiring. No need to remove the bumper. The only thing I'm still sorting is which fuse to use that will leave the DRLs on only when the car is on. Right now all the fuses I've tried are either always on or on when ACC is on. Not a big deal but something I'd like to change if someone has a recommendation.
Here is the before of the front lighting.
And here is the after.
This is how the DRLs will appear in the daytime
Here is a video of the flashers before
and the flashers and lights after
