1 - 4 of 4 Posts
2017, Fiat Spider 124, Abarth
How do you disconnect the connector under the seats to remove the seats?
We just did this three hours ago... Check the YouTube video "ND Miata Seat Removal" We looked at this first...ultimately very easy.
Best not to turn on the ignition for any reason while it's disconnected. I did that once on a Volvo and I had to buy an ODBII scanner to clear the fault :)
(The ODBII has since proved useful for other things.)
Disconnect Negative earth on battery first being VERY careful with that copper thing attached to same. (it sends info to ECU so damage that and you have a car that will not start and a very expensive part to replace. Cheers
1 - 4 of 4 Posts
