Aloha All.
FYI this Upgrade/Modification applies ONLY to Abarth model 124 Spiders as the Lusso and Classica have different Rear Side Markers.
The RED rear side marker has always bothered me and I was hoping to eventually do something about it. "I know, I know... BUT @Mike34 YOU LOVE RED! " Well this one time I don't, at least in the sense of visual lines.
So what the heck am I ranting about?
These! Aliexpress LED Rear Side Marker Light Lamp. They also have them in CLEAR lens/Red LED
They were originally listed for Mazda only...but after confirming the size and shape with the seller (great communication btw through the Aliexpress app) I can confirm they fit the Abarth. I'm sure if you looked you could get them for cheaper and or faster delivery (About $48 and took a month to get to Hawaii) Remember we have the Jones Act working against us...so the TRIP is longer to Hawaii. YMMV
Items come with the mounting screw (one phillips head per side), You MUST unscrew this phillips head then press the top snap fit and the lamp pops right out. Twist the lamp connector and remove the light bulb. Slip in the harness/ pigtail into the factory plug harness (NICE SNUG FIT) and Twist it back in. Snap in place and install phillips head. Easy 5 minute install. NO CELLS, no Warnings on the dash. All good!
May look like its not flush, but it is. Just the angle of the picture.
Screw driver and flashlight is all you need.
Now you all know how dirty these lights can get. YUCKY!
I know this is nothing like the serious work @Calehedron ( and others ) are doing. But I hope to contribute in some small way on the forum.
Anyone can do it. You can reach up and under the car without the need to jack it up. I think the only possible hiccup would be if you dropped the phillips head screw. But the underside would catch it and you could reach it with your hand and feel for it.
aloha mike
aloha mike
