The Classica and Lusso variants of the 124 are different from the Abarth. At least as far as the TPMS system goes. For some reason Fiat decided that the top of the line Abarth should be less equipped than these other models. They get to set and reset their TPMS system while Abarth owners don't. The differences don't end there though. The sensors are different. I live in Colorado, we get snow and cold (I know big surprise). While we may get the most days of sun in the country, I refuse the relagate myself or the gorgeous Spider sitting in my garge to only warm sunny days. I have a set of winter and summer tires for her and thought it would be easy to just order wheels/tires/sensors and have them put in. I used Discount Tires to do this and to be honest they have been great. They ordered the sensors ($50 each) and put them in with the expectation of needing around 20 miles of driving for the car to read the new sensors. Long story short, the sensors were never acknowledged by the car. I then went to the local Fiat dealer (for an oil change) and figured they could also get the sensors working. First, they did not have a scanner that had our 124's as an option (they also stated they had the latest version). Fiat has not put it out yet according to them. They called around and apparently found the guy that writes the software and got a patch/update. That did not work. They then stated that the sensors were the wrong ones, not OEM Fiat, and that the 'real' ones would cost $150 each.... but were not available and there was no date for when they would come in. So, 3X's the cost and not available. I went back to Discount Tire and they found that the sensors had been 'turned' off. They turned them back on and said try the 20 mile drive again. Still no love. With this being a new car it is not in all databases yet, that is understandable (to me at least). They had put in what had been recommended but what we found out is, they were for the Classica and Lusso models. The information on these was:
HUF UV4030 TQ40 RED 433 Mhz InTellisens (the yellow sensor pic)
Point of note: All of our TPMS systems work on 433 Mhz. Last night we finally got this all to work and not for the $150 each cost. They had me bring my original wheels/tires back in. They used their scanner to read the codes from each tire and recorded all 4 of them. They then used these sensors:
SCH 33500 TQ12 T10 DB-EZ Sensor (From Schrader) (the black sensor pic)
The difference is that these sensors do not come with an ID code from the start. They are programmable, which is what they did. Once they used my original sensor IDs/codes as a clone for these new sensors, it just worked. There was no 20 mile read-in time. They work on the 433 Mhz frquency. All was good. I hope this information helps some of you not go through the same hoops I had to jump through.
