1 - 8 of 8 Posts
Has anyone removed this part to get to the fuel rail or anything? There is a hose connected to the bottom of it, looks like it’s running to the intake manifold? Having a hell of a time figuring out how to get enough space to remove the clamp with how short the hose is.
@Dtgz
I removed that when I installed our powdercoated valve cover.
There is no easy way to work with that short hose.
I used a set of long nose pliers to remove and reinstall it.
I spoke many words trying to reinstall it.
Good luck
73563
Discussion Starter #6
Thanks, I knew I could get it off with a little difficulty, wanted to make sure someone actually managed to get it back on without pulling the motor though haha.
Thanks
As others have said, it's a struggle, there just isn't a good way to do it.
1 - 8 of 8 Posts
