PS: When you have an alignment done, there are a few things to keep in mind. Many techs don't bother themselves with several items, including cross-camber, cross-caster and thrust angle. If the readings on the screen are green, they hit "Print", and out the car goes. A car will pull to the side of the car that has the most positive camber (top of the wheel out to the side more than the bottom), and to the side of the car with the most negative caster (caster is the relationship of the upper ball joint to the lower ball joint in a front to rear direction - positive caster has the upper ball joint ( or upper strut mount ) behind the lower ball joint. Specs will say something like .1 deg. Camber +/- .5 deg., with a .5 deg. cross camber allowable. But most alignment machine screens will show "green" with a 1 deg. cross caster - not good. Cross camber should be as close to spec. ( In this case the .1 deg ) as possible, as camber can effect not only pulling but tire wear too! This is why we use caster to compensate for road crown. So, Walshy, if you have alot of crowned roads ( for those who aren't familiar with the term, a crowned road is one that is higher in the center than on the sides to allow for rain/water runoff) some deviation in cross-caster is good, as the car will track straight on a crowned road - so something like 7.9 deg. R/side, 8.1 deg. L/side - or close to that ( sides being determined by sitting in the driver's seat, NOT by looking at the front of the car) would be appropriate for crowned roads in the UK. For USA, Canada, etc. where we have left hand drive, you would want 7.9 deg. caster on the left, 8.1 on the right for our example. We use caster to compensate for crown because caster does not effect tire wear like camber does. And there is a maximum cross caster spec too, because it will cause pull. Also, there is this thing called thrust angle. That has to do with toe - if the rear wheels are both pointed in the same direction ( say left pointed out, right pointed in) then you will have a car that drifts off the center line of travel. When you get your alignment printout, thrust angle should be as close to 0 deg. as possible. Toe issues will cause tire wear problems, front toe issues will not cause a pull but will cause the car to feel twitchy or vague. So I like to set things as close to spec as I can get, paying close attention to the "cross" numbers as well as the base spec, and getting the thrust angle to zero. It takes time, but pays dividends in handling and tire wear. Of course, if somebody requests a bit more negative camber for handling purposes, or a bit more caster for stability ( imagine trying to ride a bicycle with the handlebars turned 180 so the fork points backwards!) I am happy to oblige. Best, s
