H&R part #29135-2 (the #2 being specific to Abarth models)
I ordered these springs from a distributor in Germany.
When doing this install, we made sure the suspension was fully compressed before torquing the upper control arm bolts and lower shock bolts. We used a floor jack under each hub till the car started to lift off the hoist before torquing the bolts.
I measured a 1.25" drop on the front, but more interestingly, a 1.75" drop on the rear. The car rides a little firmer but that was to be expected. Not harsh. So far I haven't had any issues with ground clearance.
(Update)The ride height from the centre of the wheel to the upper fender is about 12.75" front and rear.
Very pleased with the results.
Before and After
Before and After
