Have you tried this with success?Can these instructions be archived on the site somewhere to be easily found?
This is from the Spider service manual:Has anyone removed the automatic shift knob? I can't seem to figure out the trick.
Thanks for this. That's way different than what was mentioned earlier in the post. I'll give it a shot.This is from the Spider service manual:
GEARSHIFT KNOB
1.Dislodge the trim (1) on gear lever grip.
2.Work on the retaining clip (2), then remove the gear lever grip.
1.Place the gear lever in its housing and engage the retaining clip (1).
2.Fit the trim on the gear lever grip (2).
(I realize this is pretty sketchy, but this is what you get.)
Not sure but looking at the mazda unit, I would say no since there is no way to put the retaining clip back in. Also if you have taken yours off you will see the white plastic rod. That has to be oriented correctly with the shift knob in order to make it work properly. Does not look like the mazda unit would do that.Didn't want to start a new thread for this...but was thinking about swapping my auto's shift knob to the ND miata auto shift knob (part no. N24746030). No reason this shouldn't work right?
Right now, I can just pull up on the knob to remove it (while in neutral). Does anyone know if the ND shift knob behaves differently?
Thanks for sharing this. I hadn't seen your post before, but I'm going to substitute your illustration to my article Removing the (Automatic) shift knob, so that it is helpful for others in the future.This is from the Spider service manual:
GEARSHIFT KNOB
This doesn't sound right, like the retaining hardware is already missing/damaged/out of position.Right now, I can just pull up on the knob to remove it (while in neutral). Does anyone know if the ND shift knob behaves differently?
