1 - 8 of 8 Posts
Hi, wondering if I missed something 'cause I didn't find a menu to set this function when the car starts moving.
In my previous Alfa Mito Cloverleaf I could set it up to make the doors locked above 20Km/h. Strange that with such a load of technology there's nothing related to that.
Thank youuu ;).
if I am not mistaken, there is something in the settings menu for your infotainment center. if you have a classica without the infotainment center, you may not have that feature
Thanks rdass. I have the 7" system and in the vehicle menu I found several things but not that. Is there any other are to search? You have it in your system? Does the light on the Start/Stop button (Green/Yellow) or even the engine on or off affects the presence of that menu?
Ameridan, thanks for your feedback. Your article is very interesting and it really seems that they consciously removed that voice from the menu. I didn't check with others here in Italy but I can ask a friend of mine who owns an MX-5 2016. Curious to learn if Mazda Italy took a different decision about that. I also found a video in which someone unblocked that menu modifying the software with a pc connected to the ECU. I will check with the dealer if they can unblock it.
- Whiper sensor
- Doors lock timing (30")
- Turning lights menu
- Lights
- Reset
Be aware that if you are in ACC mode not everything shows up in the menu. Make sure that the ignition is ON but not running.
1 - 8 of 8 Posts
