1 - 8 of 8 Posts
Anyone know what, or if there is a change interval for this fluid? Have a 2017 Lusso. Thanks
I don’t know and won’t act like I do.
I like to keep an eye on the color of ATF. When it starts to change from bright pink to dull pinkish brown, it needs to be changed.
Lacking any specific information, I would say 50,000 miles would be conservative and 100,000 miles is too long.
It depends how you drive the car
Once again I do recommend following Mazda/Fiat's Recommendation on changing the fluid minimum
But as I am anal as hell I will probably do mine every two years or 30,000 miles regardless and the filters
Automatikgetriebe AW6R31 6/1
Füllmenge:Füllmenge (gesamt) 7,5 Liter
Einsatz:Normal
Intervalle:Prüfen 15000 km/ 12 Monate
:Wechseln 75000 km/ 60 Monate
Change at 75,000 km = 47,000 miles so not too far from my 50,000 mile conservative suggestion. Still surprisingly early, but I think that is characteristic of Mazda automatics if you want to keep them healthy.
Anyone has a description of the process for the 124? I've seen videos of the ATF being changed on older miatas and it looks like it's a "drain and refill" process with no filters.
1 - 8 of 8 Posts
