1 - 2 of 2 Posts
Aloha all...after seeing @sharkcohens install of the TORQUE SOLUTIONS BLOW-OFF VALVE ADAPTER
I decided I'd pull the trigger and install it. Simple install as I already had the GBF DV +.
Just need longer bolts 5mm allens(request them in the notes when ordering). I noticed while installing you can decided which orientation you want for the blow-off vents. Up, down, sideways etc.
I just installed with one vent up and one down. But it got me thinking.
Is there preferred orientation for the blow-off valve? Both down?
Should one worry about debris or even water from getting into the blow-off valve? Or being that its "blowing out" there's nothing to worry about?
aloha!
oh the blow off isn't very loud either...so that I'm happy about. I don't need a huge whistle!!!
forgot to mention....that nick in the housing was like that directly from the packaging...seemed small enough that it wasn't a major concern. Plus.. I figured if i did try and return it..they'ed think I dropped it.
Reactions: sharkcohen
I installed the vent ports one up, one down facing drivers side. I thought a port on the third face might be blocked by the EC intake, seeing as it rides right against it.
Reactions: Mike34
1 - 2 of 2 Posts
