1 - 3 of 3 Posts
2017 Fiat 124 Abarth
I posted about getting this combo before, requesting if this setup would fit without rubbing. I couldn't find a definitive answer, but after hours of searching and learning that other combos with taller diameters worked, I took the chance. Good news, this set up fits without issue: Breyton GTS-R 18x7 on Continental ECS 215/40-18.
Now the question is, will it fit with Eibach lowering springs?
Also, how do I find the recommended tire pressure for this tire? Is it vehicle related, in which case, 29psi? They came filled at 35lbs, and the TPMS is blinking.
79351
brey
That's one nice looking wheel..
35lbs shouldn't cause the TPMS to blink. Indeed, a flashing TPMS is an indication of a malfunction. Possibly because a TPMS sensor isn't working.
1 - 3 of 3 Posts
