OK, I see that the manual calls for the following bulbs (on a non-LED equipped car)
High Beam - HB3 60w
Low Beam - H11 55w
Fog Lights - H11 55w
LP Light - W5W 5w
Rear side marker - W5W 5w
Front Position/Side marker - WY5W 5w
I'm pretty sure the HB3 is also the same as the 9005 bulb series. But is the H11 a true H11. I know on the Toyota it called for the same for the fog and low beam lights but they are NOT the same bulb. Are the low and fog light bulbs different - the Toyota uses an H16 fog light bulb - or are they actually the same bulb on the Spider? I'm hoping someone has already pulled the panels and replaced them and can answer that so I do not have to get the bulbs, pull the panels and then find that the fog light is actually a different bulb.
The W5W's are apparently a 194 bulb base (which worked fine in my LP lights) and WY5W is probably an amber/yellow version of it.
Has anyone found/compiled a list of standard US bulb equivalencies since most of the online lists for the bulb manufacturers do not even show the 2017's yet, much less the Fiat Spider.
Currently I pull the bulb and then go into the store and find one that looks the same, but it would be nice if there was a compatibility list available.
High Beam - HB3 60w
Low Beam - H11 55w
LP Light - W5W 5w
