1 - 14 of 14 Posts
So my wife and I were cruising down I-5 in north California, 1000 miles into a 5000 mile road trip, and with no warning engine shuts off at 70 mph. I notice all power is gone, exhaust is quiet, and look at dash in amazement and notice battery light and a couple of other yellow warning lights are on. I am about to plan my exit strategy to get over to the shoulder and before i can do anything, car fires back up and carries on likes nothing ever happened. No CEL, temp guage normal. nothing! 100% back to normal running. Car had stopped running for only 2 maybe 3 seconds.
Car appears to be running 100% fine and hasn't hiccuped since.
Anyone seen or heard of this happening before?
We hit death valley tomorrow so I will be keeping my fingers crossed.:|
check that the wires to the battery are well tight and also the battery (-) to the ground is well tight.
Reactions: Unknownsir
Is the oil low?
Only thoughts that come to mind would be a loose ground (or battery connection) or a momentary freaksih issue in the ECU. If you've disconnected the battery for some reason, perhaps to do an upgrade, maybe the cable isn't tightened. Hopefully your luck will hold!
Thanks for the suggestions.:)
I did immediately check battery connections and everything was tight. And since i had a dealership oil change just before I left, I checked that too. Oil is at the correct level and spotlessly clean. Haven't done an ecu upgrade yet, but it is on the to-do list. I tend to agree with kpoling above in that it may just have been a freakish ECU issue that caused fuel or spark to stop for a few seconds. Hopefully it won't return.
This is disturbing to me, I hope it doesn't show up any more. I assume you have a MT spider, and your forward motion fired the engine. I have an AT, and I don't think my vehicle in motion will re-fire the engine.
Any more information on what happened to you?
Discussion Starter · #8 ·
Yes, MT. Not sure what would happen in an auto, but I hope you never have to find out.
Car died and restarted on its own, hadn't even had an opportunity to put the clutch in to coast to side. No other info. Have put on another 750 miles in the last 2 days. Car running perfectly, no codes, no high temps, oil and electrical connections good.
I was really hoping someone with more fiat experience than me or perhaps one of the tuners would chime in and say "yeah, we have seen it before,........"
But I guess I am the lucky first timer.:confused:
I did wonder if somehow you accidentally bumped the start button and if that momentarily shut it down.
Discussion Starter · #10 ·
We are thinking along the same lines because this morning i was thinking the same thing and when i was sitting in the car tried to figure out if it was possible. I don't think I could have bumped it and I know i didn't bump it to turn it back on.
I believe the start button is disabled at a certain speed. Not sure, haven't tried it in this car. Other cars will allow it to function up to 5-10mph, but above that it doesn't do anything.
Shutting down instantaneously is not something that Fiat would program into the car. This has to be an unintended electrical interrupt. I suggest that you look for ground wires that have come loose and lost ground, as well as powered wires that have lost insulation and gone to ground.
Reactions: bervin08
Was driving slow traffic and car started honking and flashers turned on. Pulled to the side and restarted the car. Went back to normal operation. Same problem might be?
Original Spiders could do that on occasion if one of the connections to the ignition switch became loose. One good bump in the road could instantly kill everything. Usually it would happen once and then you'd crimp the spade connectors to the switch so it would never-ever happen again. Dead stick landings are no fun! Ha! -SF
1 - 14 of 14 Posts
