161 - 180 of 331 Posts
If I install car play, what happens with my navigation card, or can I still use the car navigation or use only the Android gps. tia
Discussion Starter · #162 ·
As long as you run the Fiat / Abarth branding scripts after updating the firmware, you can use both the inbuilt nav and any navigation application exposed by CarPlay or Android Auto.
Hi there,
Thanks to @68wooley's pioneer work and @ameridan's great blog, I have successfully installed CarPlay in my own Abarth Spider and friends' cars. It works great for me since January 2019, and two more since summer 2019.
Today we did another installation. We encountered a new issue during the upgrade to 70.00.100A. After the installation of the failsafe package, the installation of reinstall package wouldn't finish. I attach the error message in German; in English, it reads something like "Validation failure/n Invalid packet certificate".
We came from 56.00.521; I verified the hash of cmu150_EU_70.00.100A_reinstall.up with previous installs to exclude file corruption (also attached, FWIW MD5 is 279f1b81e1fa43b1b43ea1af38aab834). There were a few tweaks installed, including the speedcam patch.
I didn't find any mention of this issue in this forum nor mazda3revoluion. Have you seen this before? Any idea what's going on?
Thanks,
jayrock
2019 Abarth
My eyes are crossed and my brain is fried from trying to digest so much great information on this forum. But please tell me that I am correct in what I have read to date (skipping way ahead to post this) that my 2019 with an OS Version of 59.00.5662 (picture posted) is NOT upgrade-able to use Android Auto. Thank you all that have posted in the post and to those who post in the future. This forum is great and look forward to when I can make contributions.
Chris
79088
Chris
It is, but you have to install ID7 via a serial connection first which requires taking the dash apart, not as bad as it sounds.
If you want to upgrade without doing the serial connection, it is possible, but with a different strategy if you are willing to do a convoluted firmware downgrade first to Mazda 59.00.502, which will then allow you to install id7 via USB tweak, and then upgrade to 70.00.100.
2019 Abarth
Thanks Ameridan, I've been reading your blog, but for the life of me I can not find the section that explains how to do the downgrade first. Nor can I find the right area that explains how to install the id7.2 . Haven't researched past that to learn how to install the upgrade to 70.00.100. I'm sure its there but w/o finding or understanding the first 2 steps, I'm lost. I'll go through it all again. Thanks!
2019 Abarth
Thanks Bill for your reply. I'm going to go through Ameridan's blog again and see if I can find how to do it w/o pulling the cmu (?) and doing the serial connection first. Even reading his blog I haven't found how to even go that route yet. I'm sure it's there.
2019 Abarth
Thanks Ameidan. I've never been shy in doing tweaks and such in the past. I've always enjoyed and got a kick out of how we tell systems/programs how WE want them to operate. But in this case I am so lost in reading and trying to comprehend what is required. I think I am better off living with the stock set-up and using AA from my phone when needed. I appreciate and thank you for your input here and your blog for the information and knowledge that you have shared.
So Im trying to finish this update for my wifes 2019 Abarth. I was able to do what I thought would be the most difficult part of this, the serial connection, with no problems. Ive verified through putty that the code is in the CMU, multiple times. However, whether I try to do an AIO tweak, or one of Ameridans ID7 tweaks, the car is refusing to recognize the USB drives and do the install. Im not to the FW update yet, just trying to prep for that update.
Well, thats not true, it recognize 1 of my drives, the one with the Ameridan tweaks on it, I saw the CMU display, USB FIAT2 recognized, but the AIO stick wasnt recognized. I swear Ive sat by this thing for damn near close to 20 minutes, with (the AIO page doesnt say anything about removing the card) and without a navcard, top and bottom USB drive. Im trying the full Mazda shut down right now, close everything, lock and walk away.
Any thoughts on this? I doubt its the drives, they worked fine when used for the serial hack portion.
UPDATE: So yes, shutting down the car entirely like you would in the FW update got the Ameridan ID7 to run. So if anyone is having trouble after the serial hack, try adding that step in. Shut down car, close all doors, and lock it up. Walk away for some time and come back. It booted right up for me in seconds.
A quick question. I have the 56 version, and understand I need to install the ID7 before up grading to 70.
But should I remove the tweaks already installed first? Or will they just be replaced when I upgrade?
Thanks! ID7 installed....
2019 Abarth
Making me jealous Bob!
Hopefully one day I will get there in understanding completely what I am yanking out, serial connecting to, ID7 or ID7.2 and D/Ling the right programs in the correct order. I've gotten lost in Ameridan's description, hoping 68wooley's is better. Baby steps for me.
Well it is a little easier with version 56 without the serial port involvement.
Reactions: Hogrider92
2019 Abarth
Anyone familiar with having to upgrade from version 59. have knowledge of the 2 choices of Putty or SecureCRT? One better than the other, ease of use? Also, if going the SecureCRT method, do I want the SecureCRT 8.7 or the SecureCRT + Secure FX 8.7 bundle? Thanks!
Are you using the upper USB slot? Bottom one didn't work for me.
I think the USB stick needs to be formatted to FAT32 on a windows machine, but I could be wrong. The experts should be along shortly. :)
Discussion Starter · #180 ·
I've heard people having issues with sticks formatted on a Mac. If you have a Windows PC available, use that.
Macs are a PITA the moment you want to do anything that isn't Mac.
Reactions: wrh3
