1 - 10 of 10 Posts
Just got this code in my 124 I looked up the code but it only comes up with Toyota
what google came up with....
http://obdii.pro/en/code/P1300
Definition of check engine code P1300:
Acura:Multiple Cylinder Misfire Detected
Chrysler/Dodge/Jeep:Ignition timing adjustment circuit failure
Citroen/Peugeot:Boost Calibration Fault
Daewoo:TDC SNSR MAL
Fiat:Relais pre/after heating
Ford:Boost Calibration Fault
Geo:Ignition Coil 1 Primary Feedback Circuit
GM:Ignitor Circuit
Top right of the screen,.....is that code 01 of 03?
If so, what are the other codes?
all 3 codes where the same
1 pending
2 permanent
3 freeze frame
1 - 10 of 10 Posts
