1 - 20 of 79 Posts
Retired Moderator
V4 intake is about 7 rwhp and 6 ft-lbs more than the V1 intake according to the graphs posted on the website....see below
But honestly this is what I am more concerned about...inlet air temperature as show below...the cooler average temperature of the air coming in helps the intercooler and in turn will keep me farther away from the knock sensors pulling power...especially when summer and hot temps arrive...I will take any reduction in heat I can get...especially where I live...
https://shopeurocompulsion.net/collections/fiat-124/products/eurocompulsion-fiat-124-spider-abarth-v4-air-induction-kit
that all being said if you like a little more turbo noise...then the V4 is for you...>:)
Agree, Thanks
We are going to be in Phoenix and surronding areas this coming mid-week Feb. 8thish...I'm a fellow Fiat White Luso owner. I was curious regarding some of your mod's. Mainly the noise of your custom exhaust. Didn't know if you were close and/or around and could possibly catch a quick listen.
Keep me posted. Phone call preferred 248-969-1107, not much of an emailer. If you prefer, here is my email [email protected] and I would be happy to contact you
Thank you in advance Jim from MI
Who has Installed a Cold-air intake? Type? Satisfied?
I also have tried the EuroCompulsion V1 & V4. I went with the V1 when I added the Euro+Drive Lite with the Dynamic map. I am completely satisfied with that combination, and the GFB DV+. I installed the V4 when I tuned up to the Race map on the EDL. I have only driven with that combination for about 30 miles, so I'm still evaluating.
Both intakes are very high quality and fit perfectly. If you, or anyone else, would like to purchase a used V1 intake, let me know through a private message.
Reactions: Faster2day
Reactions: sdlynx
A stupid sugestion, I have the V1 installed, Here in Quebec in the summer it gets hot but not like the US, but if stuck in traffic, it gets worst than the US heat. LOL
If I wrap the V1 with aluminum foil it will insulate the V1 from the engine heat.
Aluminum foil is not a good insulator. Aluminum by itself is a widely used heat conductor.
1 - 20 of 79 Posts
