Hello all, I’ve noticed if I let the car sit for awhile. When I start her up there’s a good lifter knock but then it goes away. Is this a know issue for this car or do I have an issue lol
Thank you very much.Yeah, it's not really "lifter knock." The intake valves on these cars are hydraulically operated. The mechanism is commonly known as the "brick" and sits on top of the engine. If the car sits for a long time without the engine running, the oil in the brick drains, and when you go to start it the lack of hydraulic pressure can result in the engine running rough for a short period until the brick fills back up and there is adequate pressure to actuate the valves fully. In extreme cases, then engine won't start at all (there is a procedure for fixing that). The length of time varies by car. My 2017 Abarth can sit for up to six weeks without giving me any problems at all. Beyond six weeks, there is a good chance it will run a bit rough on startup, but only for 5-10 seconds before it smooths out.
Same hereYeah, it's not really "lifter knock." The intake valves on these cars are hydraulically operated. The mechanism is commonly known as the "brick" and sits on top of the engine. If the car sits for a long time without the engine running, the oil in the brick drains, and when you go to start it the lack of hydraulic pressure can result in the engine running rough for a short period until the brick fills back up and there is adequate pressure to actuate the valves fully. In extreme cases, then engine won't start at all (there is a procedure for fixing that). The length of time varies by car. My 2017 Abarth can sit for up to six weeks without giving me any problems at all. Beyond six weeks, there is a good chance it will run a bit rough on startup, but only for 5-10 seconds before it smooths out.
Has yours always done this?Same here
I recognize that your query wasn't directed at me, but I too have a 2017 Abarth. I used to let it go for six weeks, but gradually over time that resulted in rougher starts... and like others have noted, it just runs rough for a few seconds and then things smooth out. But since I don't like doing that to the engine, I now do monthly startups and just let it run till the cold engine light goes out, then shut it down and tuck her back under her winter blanket till we meet again a month later. It's a well known and documented situation here on the forum. The only variable is how long it can sit between start-ups without the brick draining enough oil to result in a rough engine start. Though the same engine is used on other vehicles, I think we're the only ones who've experienced this because most vehicles are used as daily drivers. Because of the Spider being what it is, a lot of us in colder climates choose to garage them over the winter months, resulting in the drainage problems not seen by those who daily drive their vehicles (Spiders or other models using the same engine).Has yours always done this?
I do the same. Start up day today so pulled the covers off to give Rita,Ruby and Sallie ( not Daisy the dumper) a little warm up. Would have liked to take them out for a bit of a run but for the first time in 11 years we have snow on the ground. ❄🌨I recognize that your query wasn't directed at me, but I too have a 2017 Abarth. I used to let it go for six weeks, but gradually over time that resulted in rougher starts... and like others have noted, it just runs rough for a few seconds and then things smooth out. But since I don't like doing that to the engine, I now do monthly startups and just let it run till the cold engine light goes out, then shut it down and tuck her back under her winter blanket till we meet again a month later. It's a well known and documented situation here on the forum. The only variable is how long it can sit between start-ups without the brick draining enough oil to result in a rough engine start. Though the same engine is used on other vehicles, I think we're the only ones who've experienced this because most vehicles are used as daily drivers. Because of the Spider being what it is, a lot of us in colder climates choose to garage them over the winter months, resulting in the drainage problems not seen by those who daily drive their vehicles (Spiders or other models using the same engine).
Beautiful collection, even daisy🥰I do the same. Start up day today so pulled the covers off to give Rita,Ruby and Sallie ( not Daisy the dumper) a little warm up. Would have liked to take them out for a bit of a run but for the first time in 11 years we have snow on the ground. ❄🌨
Thank you. Daisy is such a great machine.Beautiful collection, even daisy🥰
My P Zero Nero's are allergic to snow and ice, so that's not going to happen in my case. lol Okay, full disclosure... I also change my insurance coverage to a "garaged" status during the winter months, because, well... sometimes I'm a cheap ba$tard.One negative I’ve read here about regular start-and-runs is condensation in the exhaust system. I’m going to try address that by being more open to taking the opportunity to drive my Spider.
Hi Cal, some condensation in the exhaust system is the least of my worries, both as a technician and as an owner of a 124 Spider, Abarth version. I too put my car away for the winter - at a climate controlled indoor automotive storage facility ( www.portlandmotorclub.com ) , and, being the cheap ba$tard that I amMy P Zero Nero's are allergic to snow and ice, so that's not going to happen in my case. lol Okay, full disclosure... I also change my insurance coverage to a "garaged" status during the winter months, because, well... sometimes I'm a cheap ba$tard.![]()
Joking aside, my understanding is that letting the engine run long enough to turn off the cold temp light is doing as much to mitigate the condensation issue as taking it for a short drive, and our exhaust system is stainless steel so it shouldn't be rusting. It's only if you run it a short time then shut down that it becomes something to worry about.... I think. I could also be dead wrong in those assumptions.
@SteveP. , what's the thoughts on this from a dealer service perspective? I know condensation is a natural byproduct of the fuel combustion process, and we've all seen water dripping from tailpipes on vehicles. If it truly is a serious issue, then I find myself between a rock and a hard place. I'm not going to winter drive the vehicle, but because of that, I also need to do regular starts to keep oil in the brick.
Rest assured that when I do drive my Spider in the winter I do so very gingerly within my 25 mph neighborhood.My P Zero Nero's are allergic to snow and ice, so that's not going to happen in my case. lol Okay, full disclosure... I also change my insurance coverage to a "garaged" status during the winter months, because, well... sometimes I'm a cheap ba$tard.
