1 - 4 of 4 Posts
Looking to convert single tip exhaust to dual, yes unfortunately for appearance only so entire stock exhaust stays. Anyone done this yet, and if so what part/ manufacturer did you use, and how does it look?
I'm guessing you'll need to visit a good local muffler shop and have them do a little cutting and maybe some welding, probably pretty basic, moderately priced work from them. I've not seen an option for single to double tips only work discussed here. Everything seems to be full component replacement, such as the complete muffler section downstream of the midpipe.
Thanks guys. Either solution works. The clamp on look good as the clamps will not be visisble.
1 - 4 of 4 Posts
