1 - 4 of 4 Posts
Ok so I've already had my top replaced once...no matter how I maneuver the top when I put it down it rests on the roll bar on the driver side. I know I'm not doing anything wrong and I'd rather not have another top put on if I don't have to. But the clearance on the driver side is none and the passenger side has plenty. Idk if it is because the latch is located more towards the driver than the passenger or what. Any help is appreciated.
If the problem is not with the top or its mounting hardware, maybe the problem is with the driver's side roll bar. What you see is just a cover. There may be a broken weld or something underneath it.
Found part of the issue. My seat is all the way back and is flush with the back of the car. Headrest pushes against the appliqués and adds just enough push so that it rubs. Moveit and there is less than a millimeter of clearance
1 - 4 of 4 Posts
