1 - 14 of 14 Posts
Gee. My wife is the same height (165cm) and is she is fine. And I'm 180cm and I really wish that the seat went lower! Are you used to sitting high in a car?
Reactions: fuzzi
Reactions: fuzzi
I am 162.5cm tall and I feel good in the seat. I do not like the front edge up, so i used the knob to lower it, otherwise i fell ok. I also understand the feeling that you will never feel like you can see the front of the car while you are sitting so low.
Reactions: fuzzi
I'm 5'9". I must be all legs because I need the seat all the way back to feel comfortable. I seem to be really hunkered down low in the cabin but I love the view this way in the Spider. Plus I get to admire a great view of the curvaceous front sides. ;)
Arm position is number one priority. You should be able to sit in the seat, without "reaching" (your shoulders should still be touching the seat back) and you should be able to rest your wrists on the top of the steering wheel. If you can't reach, then you are sitting too far from the steering wheel. Any performance driving instructor will tell you this. This is how I like to be seated.
Being short that is the great thing about being able to lower the steering column and not just tilt the steering wheel. The only draw back is that at times that also means i lower the column and block part of my view of the dash in some vehicles. Sometimes i only lower it far enough that it almost obstructs the speedo but not as far as i wish i could. Anyone getting in after me must raise the column or they won't get in. Also i am not usually comfortable unless my left foot can rest on the left rest spot. In a manual Wrangler the seat needs to be so far forward in order to push in the clutch that my knees actually rest on the knee blocker under the column.
Reactions: Magoffin
My wife doesn't care for how deep the seats are in her Lexus. She actually looked into getting additional padding added but the prices we were quoted was insane.
That said, she actually doesn't mind the seats in the 124 at all. She's 5'4"
Reactions: fuzzi
This is why I wish the Abarth had telescopic adjustment on the steering. For my arms to be in the right position, I'm very slightly too close for my legs. Same problem on my MX5 of course!
Reactions: fuzzi
2018 124 Spider Lusso Red Top Edition, Automatic, Fashion Gray, Ivory Interior, Bordeaux Top
I'm 165 cm and interestingly, I do like the front edge up, I don't like the feeling of "sliding down" in the seat when it is too flat, as happens on most airliner seats. I like the underside of my upper thighs lightly supported.
One ergonomic complaint for me is that the "dead pedal" is too far away. When I set my seat position, I can fully operate the accelerator pedal and brake pedal (I have an automatic), but I cannot touch the dead pedal without reaching for it with my toes. I've been contemplating how to fabricate and install a spacer for it.
1 - 14 of 14 Posts
