1 - 9 of 9 Posts
After a couple of hundred miles and adaptation feeling better each day, I can honestly say I'm more than satisfied with Madness 500 engine control module.
Torque and hp increase is impressive.
Great through the power ban.
That's pretty cool. How much boost pressure is it running on? I wonder if this level of boost would shorten engine life by much... if it isn't too much I might consider getting one too.
There are few different ones available, they are designed to stay in safe levels of boost and timing.
It really improves the driving experience.
How involved was installation?
It's basically plug & play, I didn't remove the tire, just turned hard left and removed the one plastic shield to access the boost sensor.
The good thing about the madness 500 module, is a thirty day return policy if not satisfied.
They're also very forthcoming with all info.
They have also just tested their CAI and two versions of exhaust, which should be available very soon.
Hope this helps
Do you have any dyno results to quantify the increases. "Impressive" is such a vague term.
1 - 9 of 9 Posts
