The anti-theft protection is the icing on the cake for me.
That is a cool feature. I'm a little sad that I'll NEVER use the SNOW feature. Well..not really. I suppose I could use it in the rain?The anti-theft protection is the icing on the cake for me.
Hey man....throw a couple of cups of that cool Shave ice under the wheels. That should give you the effect.That is a cool feature. I'm a little sad that I'll NEVER use the SNOW feature. Well..not really. I suppose I could use it in the rain?The anti-theft protection is the icing on the cake for me.
Aloha
It interacts perfectly with both modes.How does it interact with Sport mode on Abarths?
Don't be sad about that! Trust me on this one...That is a cool feature. I'm a little sad that I'll NEVER use the SNOW feature. Well..not really. I suppose I could use it in the rain?
Aloha
Lol.Don't be sad about that! Trust me on this one...That is a cool feature. I'm a little sad that I'll NEVER use the SNOW feature. Well..not really. I suppose I could use it in the rain?
Aloha
Checked the installation instructions on the EC site. It’s not working yet. Hopefully it will be up the first of the week.
@[email protected]Checked the installation instructions on the EC site. It’s not working yet. Hopefully it will be up the first of the week.
Its very simple and instructions will be added shortly. It simply plugs into the OBD2 port and the connector on the gas pedal.
My bad ...apologies ...it is a much different beast, but does sound like it will be very easy to install.Its very simple and instructions will be added shortly. It simply plugs into the OBD2 port and the connector on the gas pedal.
To get the car out of anti-theft mode you need to type in the secret code. It's simple and you won't forget how to do it, but I don't want to post it here. It literally takes about 2 seconds and you can drive the car again.@Greg
The anti-theft mode...if you forget that it's engaged. Do you just hit the mode button to get it active? Restart the engine?
It's easy to install. There are two two different ways to do it. It's a little different from the competing products because its extra processing ability requires 12 volt power. Super short unofficial instructions to follow: You start by unbolting the gas pedal. There are two easily accessible bolts and it lifts right out. You then unplug the pedal and plug the Pro Pedal's harness into the pedal and into the car's wiring harness (meaning the plug that was plugged into the pedal.What about connections to the car? I haven't seen/heard anything about that. Connectors? Splices?
The control module is incredibly small and light. The included Double sided tape works perfectly. I suggest mounting it to the left of the steering wheel. That makes is super easy to route the wires under the dash because they can pass through the steering column space.Mounting of the module? Velcro? Double Stick tape?
That sounds like what I did. I suppose I should post a picture of my 124 installation. In my case the control module is blocked from easy sight, but it's not a tachometer, I don't look at it very much. I can easily put it in or out of snow mode or take it out of FTL mode without looking at it, which is by design. For anything else, I have to move my head to see it, but once I find the setting I like, I don't mess with it too much.Where did you mount yours? I'm looking at above the left side vent or below and above the switch panel. To the right of that towards the steering wheel is a good spot (flat) but I wouldn't be able to see the module (unless the wheel is turned).
Thanks!Aloha EC crew.
Aloha Mike.@[email protected]
Can you run a OBD reader at the same time?
If so, looks like the OBD extension cable I bought won't work..DARN.Looks like I'll need to get a Y OBD cable. So I can run it and the OBD Fusion app.
Aloha mike
Perfect @Greg appreciate the explanation.Aloha Mike.@[email protected]
Aloha mike
You can run this and your fusion app at the same time, however you will need to connect the unit to power and ground. We include instructions to do that. We suggest using posi-taps for this as they will eliminate any need to cut wires.
