1 - 1 of 1 Posts
General Information
  • Body Style - Roadster
  • Assembly Plant - Hiroshima, Japan
  • EPA Vehicle Class - Two-seater
  • Introduction Date - Summer 2016
Body and Chassis
  • Layout - Monocoque unibody; front and rear suspension subframes
  • Construction - High tensile strength steel body to improve rigidity; double-wishbone suspension at the front and multi-link at the rear; sport suspension
Engine: 1.4-Liter Turbocharged Multiair I-4
  • Availability - Standard
  • Type and Description - In-line four-cylinder, liquid-cooled, turbocharged
  • Displacement - 1,368 cc
  • Bore x Stroke - 72.0 x 84.0
  • Valve System - MultiAir 16valves
  • Fuel Injection - Sequential, multiport, electronic, returnless
  • Compression Ratio - 9.8:1
  • Maximum Turbo Boost (psi / bar) - 2.49 bar
  • Power (SAE) - 140 hp (103) @ 5,000 rpm
  • Torque (SAE) - 240 Nm @ 2,250 rpm
  • Max. Engine Speed - 6,500 rpm
  • Fuel Requirement - gasoline
  • Oil Capacity - 3.8 liter with dry filter
  • Coolant Capacity - 7.2 liter six-speed manual
  • Emission Controls - Three-way catalytic converter, heated oxygen sensors and internal engine features
  • Towing - Not recommended
  • Engine Assembly Plant - Termoli, Italy
C635 Six-Speed Manual Transmission
  • Description - 1st, 2nd, 3rd, 4th gear: Triple cone
  • Gear Ratio - 1st 4.363, 2nd 2.348, 3rd 1.647, 4th 1.262, 5th 1.000, 6th 0.844, Reverse 3.863, Final-drive Ratio 3.454
Electrical System
  • Alternator - Denso SC2 150 A with LIN regulator
  • Battery - Q85
Suspension
  • Front - Double wishbone front with stabilizer bars
  • Rear - Multilink rear with stabilizer bars
Steering
  • Type - Double pinion electric power assist system (DP-EPAS) – rack and pinion
  • Overall Ratio - 15.5
  • Turning Diameter (curb-to-curb) - 9.4 m
  • Steering Turns (lock-to-lock) - 2.7
Brakes
  • Front - Ventilated front disc
  • Size and Type - floating – disc plate F 280mm
  • Swept Area (per caliper) - 67.8 sq. cm
  • Rear - Solid rear disc
  • Size and Type - floating– disc plate F 280mm
  • Swept Area (per caliper) - 63.0 sq. cm
  • Power-assist Type - Vacuum booster
  • Four-wheel anti-lock brake system (ABS) - Standard
  • Electronic stability control (ESC) - Standard
  • Parking Brake Type - Mechanical (lever type)
Dimensions and Capacities
  • Wheelbase - 2310 mm
  • Track, Front - 1,496 mm
  • Track, Rear - 1,503 mm
  • Overall Length - 4,054 mm
  • Overall Width - 1,740 mm
  • Overall Height - 1,233 mm
  • Approach angle, degrees - 13.1
  • Curb Weight, pounds (kg) - 1050 kg (manual transmission)
  • Fuel-tank Capacity - 45 liters
Accommodations
  • Seating Capacity — Front - 2
  • Head Room - 950mm
  • Legroom - 1,096mm
  • Shoulder Room - 1,325mm
  • Hip Room - 1,320mm
  • Seat Travel - 210mm driver / 170mm passenger
  • Recliner Range (degrees) - From 25 nominal, 12 forward and 22 rearward
  • Cargo space - 140 liter
Tires
  • Availability - Standard: 124 Spider
  • Size and Type - 195/50R16 three-season
  • Mfr. and Model - Yokohama Advan Sport V105
  • Revs per km - 1,414.6
  • Availability - Standard: Lusso
  • Size and Type - 205/45R17 three-season
  • Mfr. and Model - Bridgestone Potenza S001
  • Revs per km - 1,377.6
1 - 1 of 1 Posts
