You mentioned the Roadster Sport version was "okay" with the Bilsteins. Can you elaborate? Or are the the standard ones the way to go for street and occasional autocross.
Thanks
Our regular
Progress Springs are the way to go for regular street driver. They will do autocross better than the stock setup but don't expect to be winning events, they are still relatively soft, designed to be well within the damping control of the stock shocks and comfortably lower the car.
If Autocross is really in the plans, then our higher rate 300/200
RoadsterSport Springs is a far FASTER setup. They do work 'okay' with the Bilsteins but you lack any control over final balance, they were really designed to shine when used with the KONI and they are pure magic with the KONI. We worked with KONI from the start of the RoadsterSport Spring project, we had shock dyno info early and worked with their engineers and exchanged info on rates, etc. Result is a combo that can do a lot more than just show up and have some autocross fun..it actually crushed the field at first event we ran the setup. Normally you need a set of coilovers with much higher spring rates to get Top Time of Day at our events here with so many fast competitors, including numerous national champions. I turned Top Time of Day despite hitting a cone on both my fast runs, which means my time was MORE than 2 seconds faster than all competitors, which is all day by autocross standards. One of our younger drivers, Sean, jumped in our Fiat for exactly one run, had never driven the setup before...and turned a top five time, that's just how good the setup can be when the shocks and springs are a carefully matched combo and enough rate so you can push the car without being on the bumpstops. And ride quality is still great. This setup is more serious than most need or want, it's for the guy who wants to be fast in the canyons, fast on track, fast for autocross...and yet does not want to lay down the serious coin for something like our Ohlins coilovers. Sean below on his one run....he came back with a big silly smile, a top five time, and telling me he this setup would be his choice for a daily driver Fiat 124.
