I'm wanting to get these since they are on sale on EC, but I'm wondering if I will need a camber kit since the drop is over an inch. Has anyone installed these yet?
That's one thing a lot of people forget or either don't know about doing after getting suspension work like this done, good advice.It probably would be wise to get your alignment reset to optimum specs.
I haven't driven the Abarth yet. VS. the 124 it's a bit stiffer, but not at all objectionable. I love them, and so do the others who drive the car including my wife.How do the H&R lowering springs effect ride quality? My Abarth came with Bilstien shocks and I wouldn't want the ride to be any firmer.
I agree. However I think even stock the car should be realigned. I personally dislike the stock alignment specs.It probably would be wise to get your alignment reset to optimum specs.
Have you re-aligned the car to be out of the oe specs ??I agree. However I think even stock the car should be realigned. I personally dislike the stock alignment specs.
That said, With H&R springs, you can put them in and go. The drop doesn't cause enough of a change to make a noticeable difference in alignment or tire wear. I credit the suspension design for this. It's a really good setup that doesn't have a lot of camber or toe change as it moves up and down, at least not compared with a typical Strut type setup.
What alignment specs would you recommend for a "stock" Lusso?I agree. However I think even stock the car should be realigned. I personally dislike the stock alignment specs.
Thanks, I plan to get an Abarth of my own, but your offer may help us with some things. Is you car an auto or manual? Please PM me.Thanks for the input. Greg, I'm in AR currently for work until February and am not too far from the shop in Oklahoma. If you ever wanted to test drive the Abarth or use it to develop some things just let me know.
Ohh, I hope I don't start a flame festival. Alignment gets some people pretty fired up, and it's all largely a matter of opinion and personal preference. I like a hair more negative camber and castor than the factory used.What alignment specs would you recommend for a "stock" Lusso?
How thick a "hair" would that be for each? >Ohh, I hope I don't start a flame festival. Alignment gets some people pretty fired up, and it's all largely a matter of opinion and personal preference. I like a hair more negative camber and castor than the factory used.
I need to apply every possible disclaimer here. I certainly haven't settled in on final numbers as I haven't had the car that long (none of us have). I don't know how the tire wear is going to be long term, I haven't driving in the rain, and I certainly haven't tried very many combinations.How thick a "hair" would that be for each? >![]()
