To start off, I have the Abarth 124 and right now its slightly over 17K miles. Bought used and warranty just ran out in January. Completely stock until this month where I added the GWR system one, and tried to flash to the EC Phase 1 tune. Ambient temps are mid 40s so I spend a decent chunk warming the engine before I get moving.
I initially fell into a similar issue as Evolved did here though ultimately I was able to flash PH1 + burbles. I have more info in this thread but I feel like this is worth its own, vs adding onto that. When I flashed PH1 successfully, I missed the throttle remap procedure. First 2 days of driving it was great. Nothing out of ordinary, warm the car up, don't get on throttle harder until after a few minutes after the car no longer says it's cold. Then in 2nd, low rpms (~2k) I begin to head up a hill near my place. Car begins to bog down hard, and I see the electronic throttle control (lightning bolt) light on the dash. Clutch in, and put it in first and head back home. Briefly had a rough idle, that was the only time it has had a rough idle.
When home, check the code and its P0106. Per this thread's advice I inspect connections and clear the code, see if it comes up again. I'm no mechanic so my visual inspection could be a crap job for all I know. Car runs fine for a while, lot of fun with burbles. Then one morning I have to run to the airport, I'm rushing so I didn't warm it up as long as I usually would, maybe 3 mins this time. Driving out of the garage in 1st it feels a bit lurchy and strange at very low rpm. I get out of the garage and shift to 2nd to go up the hill. As I go up hill the car completely bogs out and stalls, you can read that info in the above post. I got it towed back into my garage and let it sit.
It was at this point I reached back out to EC for help, and have been in contact with Toby helping me figure out what's wrong. Running ideas were either A, throttle learn process was a miss and messed things up. Or B, there may have been some sort of compression issue with the tune files. Suggestion is flash back to stock if possible and run it and see what we got. After a good few hours, the car finally started reliably, and I drove it around the parking garage to make sure it would move. Checked for codes but there were no codes or CEL there. Flashed back to stock and this time I did it the right way and did the throttle map process.
Now per Toby's suggestion I drive it stock and see if anything comes up. I let it warm up fully, cold light is gone, and wait a minute further. Feels good in 1st, just like it did before I started this whole tuning thing. Shift to 2nd and about to turn and go up hill, when I start to bog down hard again. Lightning bolt light and flashing CEL on the dash pop up. Clutch in, down shift to 1st and rev it high out of a little panic. No stall, so I take the long way back home to avoid hills and having to tow again. Had to keep the RPMs around 3k to feel comfortable it wouldn't stall on me.
I check the codes today and I see P0106 and P0300, MAP sensor and random cylinder misfire. Right now my current thought is my car is running lean due to P0106, hence the bogging out at low RPM (not sure if running lean can affect starting the car like it did that once). Since cars running lean, I think it makes sense for a random misfire for P0300 since there wasn't enough fuel to ignite. Does anyone have any ideas on next steps? I need someone else to take a look I know that, but is this something I need to go to the dealer for? Or a different mechanic would cut it.
For anyone at EC, any thoughts as to why this may be happening? Car was running great before flashing, but I would imagine flashing back to stock and doing the throttle remap would remediate something. Figure something may have been wrong with the car already and tuning it could have made it worse, but I'm having a hard time understanding how, or why it seems even worse after flashing back to stock.
Any ideas or references would help here!
