1 - 18 of 18 Posts
Our new MADNESS MAXFire High Performance Ignition Coil Kit offers not only better performance over the factory parts, but also a better value!
These Coil Packs are highly recommended if you any ECU upgrades. Get rid of the stock inadequate coil packs with the new MADNESS MAXFire High Performance Ignition Coil Kit
We are very confident in our coils and strongly believe that our MAXFire Ignition Coils are one of the best if not the very best option for replacing your old coils.
We back our MADNESS Ignition Coils with a Lifetime Warranty!
Guaranteed for as long as you own your FIAT!
Contact us directly or visit our website for more information
https://shop.500madness.com/fiat-12...rmance-ignition-coil-pack-set-maxfire-pid4549
Let us know if you have any questions
Discussion Starter · #2 ·
Our MADNESS MAXFire High Performance Ignition Coil Kit offers not only better performance over the factory parts, but also a better value!
These Ignition Coils are featured on our 124 ABARTH!
Also featured here is our MAXFlow Intake System for the 124 Spider!
MADNESS MAXFire High Performance Ignition Coil Kit: https://shop.500madness.com/fiat-124...axfire-pid4549
FIAT 124 SPIDER MAXFLOW INTAKE SYSTEM: https://shop.500madness.com/fiat-124-spider-maxflow-intake-system-gloss-red-finish-pid4424
MADNESS MAXFire High-Performance Ignition Coil Kit
We back our MADNESS Ignition Coils with a Lifetime Warranty As Long As You Own Your FIAT 124!
Also along with the Lifetime Warranty, we are a US Based Company and if you have any issues with your MAXFire Coils we will always be here to help at just a call or email away!
LIFETIME SATISFACTION GUARANTEE
- Easy to install
- Includes a set of 4 Coil Packs
- Will work on stock and modified vehicles
- Will reduce engine misfiring or breaking up at high RPMs
Grab an upgrade today of our MADNESS MAXFire Coils at the link below:
https://shop.500madness.com/fiat-124-ignition-coil-pack-set-maxfire-high-performance-pid4549
Customer Review of the MADNESS MAXFire High-Performance Ignition Coil Kit!!
"Just wanted to say thanks for holding the parts and your guys help today. Just wanted to say again I am truly impressed with service and parts. My misfiring issue is gone and power at all rpms and speeds is nice and smooth. Was a super easy install." ~ Chad Will
Get rid of the stock inadequate coil packs with the new MADNESS MAXFire Hi Performance Ignition Coil Kit!
If you notice the engine starting to misfire/ breaking up at higher RPMs this set is a great way to fix those issues. These Coil Packs are highly recommended if you any ECU upgrades.
Grab the MADNESS MAXFire Coils at the link below:
Time to upgrade or replace your factory ignition coils?
Our MADNESS MAXFire Hi Performance Ignition Coil Kit offers not only better performance over the factory parts, but also a better value!
For the full details on how to get the MADNESS MAXFire Ignition coils for your FIAT 124 please visit the link below:
FIAT 124 Ignition Coil Pack Set - MAXFire High Performance - 500 MADNESS - Auto Parts and Accessories
Our MAXFire Hi Performance Ignition Coil Kit is just the thing if you need a replacement for your older coils or have upgraded the power of your FIAT 124 and now need a higher quality set of coils.
We have been using these same coils on our own fleet of modified test vehicles with excellent results.
These Coil Packs are highly recommended if you any ECU upgrades. Get rid of the stock inadequate coil packs with the new MADNESS MAXFire Hi Performance Ignition Coil Kit.
For the full details on the MADNESS MAXFire Ignition Coils for your FIAT 124 please visit the link below:
Discussion Starter · #8 ·
Discussion Starter · #9 ·
Our MAXFire Coils have earned a reputation for reliability, performance and value in the FIAT community with countless drivers from all over the world. Well tested and used by enthusiasts from all over the world.
For more information on the MADNESS MAXFire Ignition Coils for your FIAT 124 Spider please visit the link below:
Discussion Starter · #10 ·
Discussion Starter · #11 ·
Discussion Starter · #12 ·
If you would like more details on these MADNESS MAXFire Ignition Coils for your FIAT 124 Spider please visit the link below:
Discussion Starter · #13 ·
Customer feedback on their MAXFire Ignition Coils!
"These coils are great!! I changed to them @95K and the difference was noticed when 1st started. The $ is second to none. Nice warranty as well. ~ Ned C"
If you would like to see more information on the MADNESS MAXFire Ignition Coils for your FIAT 124 Spider 1.4L Multi-Air Turbo please visit the link below:
MADNESS / SEMA Abarth 124
Hi Madness.
Can you provide technical performance data on these compared to standard coils please.
Hi JohnyMac,
That data's not available to disclose. Anecdotally, OEM coil packs work fine for most stock to lightly modded applications, but can have some trouble circumstantially with excessive heat, low octane, and other variables that affect the cylinder burn. The MaxFires close that gap and can also hold up to higher boost a bit better. Users out there running bigger turbos and/or the most aggressive tunes usually want the peace of mind that comes with the OEM Bosch Alfa 4C packs, though availability on those can vary right now in the US.
The MaxFire packs are a solid replacement/upgrade for the OEMs should you need/want to do so, and they come with a lifetime warranty for as long as you own the car. We run them on most applications, even some pretty aggressively tuned cars. However, some users prefer to put their faith in an OEM upgrade and we completely respect that - especially if you're pushing pretty aggressively over the 6k rpm point regularly.
You can call/email me directly with other questions or for more info, I'm happy to share what I can.
Hmmm...ok.
After 45 years as an auto electrician, ánecdotally' gives me shivers.
I have found if a manufacturer is 'worth their salt' then specs are more than easy to come by.
They're proud to have made something 'better'.
And I like the 'lifetime warranty' bit. Not.
Discussion Starter · #17 ·
Hmmm...ok.
We appreciate your feedback and you are certainly entitled to your opinions as are others.
Our company has been providing parts and accessories to the FIAT community since FIAT came back to the US. We also own a 124, several 500 models and even 500 and 600 classics ourselves. Both our CA and TX locations service, repair and modify FIAT vehicles regularly. We have served thousands of owners from all over the world and stand behind our products if there is ever an issue.
These coils were made to the same specs as the 4c coils and we have been offering them for years. We stand behind our lifetime warranty on these with zero exceptions. No one has ever been refused a replacement if one ever failed. If these are not your cup of tea, no problem. We are here to assist if you ever need anything else.
We are also sorry to hear our answers do not satisfy you.
Discussion Starter · #18 ·
Is it time to replace the factory ignition coils in your FIAT 124?
For more information on the MAXFire Ignition Coils for your FIAT 124 Spider please visit the link below:
1 - 18 of 18 Posts
