1 - 4 of 4 Posts
When launching the car is it best to keep the pedal 3/4 of the way down halfway down do I have to feel the turbo to see where I’m getting the most acceleration at? What I have figured out is that flooring it doesn’t do anything you kind of have to hit the sweet spot of the turbo am I thinking correctly?
You need to hit the sweet spot of of your tire's traction to get off the line. How high an RPM you run at launch is completely dependent upon, How much grip you can get off the line. To little RPM and you bog down. Too much and you spin your tires. I try to launch around 3400 to 3800 RPM and I got a 14.2 quarter mile out of it. Now if I wanted to spend some time heating up my tires By spinning em and wearing out my clutch, I might have been able to shave as much as 2/10 off that time and launched 500 rpm higher.
Reactions: doverosx
The electronic throttle control makes it difficult, you may actually be at WOT at 3/4 pedal. I really miss throttle cables.
1 - 4 of 4 Posts
