21 - 24 of 24 Posts
Question how hard is to remove the shift knob. When putting it back do you have to put some loc tite or just screw it on till tight, will it align in its original position. tia
Discussion Starter #22
Not too bad. You just unscrew it like any nut or bolt. When putting it back on, you tighten until it's in the right position. If it's too loose, you give it another 360 degrees. It wouldn't hurt to put some blue loctite on it but I don't think it's necessary.
Ok guys, just received the REDline boots and looking at the pictures , the alignment is not the same do I need to do a little cutting to join th e 2 small holes. here is a picture of the boots, Maybe you guys can guide me better. tia
thanks guys, I did it but the hard way. I did cut between the holes. Job is done
21 - 24 of 24 Posts
