Everything hooks up correctly EXCEPT I have one problem that could cause another problem (hole in plastic coolant reservoir) if I operate the way the bar is hooked up. The brace bar and mounting brackets came as a kit. On the driver side: the inboard location where one side of the brace bar hooks up to that side shock tower mounting bracket has a problem where after everything hooked up and tightened the bolt head rests directly against the upper side of the plastic coolant reservoir. There is no space detectable between bolt head and the reservoir. I have tried different fixes but none seem to rectify situation. Anybody else done this mod and encountered same problem? I will call vendor on Monday and see if he has a recommended fix or can recommend a different brand of brace bar. I would be interested also if anybody can recommend different brand brace bar you may have installed
