1 - 12 of 12 Posts
Introducing the new Power+ ECM by SILA Concepts!
For those wanting to quickly install a little more power in their FIAT 124.
Plug and play tuning module that is designed to give your turbocharged FIAT a significant and safe boost in power.
Made in Germany, the Power+ Module from SILA Concepts carries approval and qualifications from Emitel, TÜV SÜD along with DEKRA Certification.
For the full details on the new Power+ by SILA Concepts please visit the link below:
FIAT 124 Engine Control Module - Power+ by SILA Concepts - 1.4L Multi Air Turbo Engine - 500 MADNESS - Auto Parts and Accessories
Looks very promising and the price is nice too!
So I have to ask, what would be the reason to buy the more expensive MaxPower ($599) over the ($399) Sila Power+? Both claim to deliver gains between 15% and 20%, so I'm wondering under what circumstances one would be a better solution over the other.
TX_Bandit,
Thank you for reaching out to us.
The Power+ is a basic plug-and-play with a lower power ceiling than the MAXPower PRO.
It's comparable to the previous generation MaxPower unit in terms of output, and in that there's a noticeable difference between this lightweight puncher and the heavy hitter MAXPower Pro.
After phasing out the last-gen MaxPower unit, we found that we would still get requests here and there for something that was just a little milder (for those who would err on the side of caution) and just a little easier to install overall. The Power+ fits the bill for that user who's pretty happy with the vehicle as-is and actually does want "just a little extra".
Or for the user who's a bit more intimidated by the idea of modifications, this is even more user-friendly on the install. It's a two-sensor connection. No power connector. No cam or fuel rail connector. That's it. 10mm socket and maybe a dental pick or a flathead screwdriver for the clips.
Regarding power output:
The Power+ will give you a nice bump to hp and tq - however the MAXPower Pro will hit a bit harder at the peak, AND sustain that delivery deeper and longer over the curve, It's simply a more capable unit.
If you have any other questions please feel free to reach out to us directly and we can have one of our Team Members answer your questions personally.
Thank you again.
Discussion Starter #5
Is there an install manual to view somewhere
Rawfiat,
Our I.T. department is currently adding installation manuals and videos to many products on our website.
The installation for the SILA Concepts Power+ should be on the listing in the near future.
We do have the installation for the MADNESS MAXPower PRO available.
https://500madness.com/500madness/pdf/FIAT 124 MAXPower PRO Installation.pdf
The SILA Concepts Power+ only uses two of the sensors and does not need its own power supply, so the installation will be less in depth.
As always please don't hesitate to reach out to us directly and one of our Team Members can help explain the installation process.
Thank you again.
Discussion Starter #7
Tks for your reply... Which two sensors does this unit use?
RAWFIAT,
The SILA Power+ uses the Manifold Air Pressure and the Boost Pressure sensors.
Please feel free to reach out to us directly if there is anything else we can do to assist you. (512)982-9393 or (562)981-6800
Thank you again.
Discussion Starter #9
Is the Power+ a passive device, or is it powered by the sensor wire?
GuidoVeloce,
Thank you for your interest in the Power+
The new SILA Concepts Power+ is powered via the sensor wires.
Please don't hesitate to reach out to us if you have any other questions.
Discussion Starter #10
The Power+ offers user friendly installation!
The Power+ ECM by SILA Concepts is designed to offer an easy, user-friendly plug and play installation and removal. The module requires no special tools and offers a completely reversible design, with no permanent modifications to any factory components.
  • Plug-and-play installation
  • No special tools required
  • Factory style harness and connectors
  • Preconfigured and ready for use immediately after installation
For the full details on the SILA Power+ Engine Control Module for your FIAT 124 please visit the link below:
Discussion Starter #11
The Power+ ECM is a well designed, thoroughly tested plug and play adjustable tuning module that is designed to give your vehicle a significant and safe boost in power.
Power+ Engine Control Module By SILA Concepts
The Power+ ECM is designed to safely raise the performance of your vehicle without over stressing the factory components.
To view the full product details on the Power+ ECM by SILA Concepts for your FIAT 124 please visit the link below:
Discussion Starter #12
1 - 12 of 12 Posts
