I realize now what I thought I posted wasn't what I was thinking I posted. Let me try and clarify.
The voltage flicker I referred to is technically called PWM (pulse width modulation). PWM is a cheap workaround for auto manufacturers that allows the high beam halogen headlamps to run at reduced power to provide the DRL function. It's done this way because the maximum safe, effective and legal brightness for a DRL is much lower than the minimum for a high beam headlamp. It is a half-assed solution, but it meets legal requirements, it's cheap to install, and that's pretty much all the automakers care about. LEDs bulbs are different than halogen bulbs in that they are instant-on and instant-off, so PWM feed doesn't dim them--it just makes them flicker.
LED lights can flicker when used as a DRL for a variety of reasons. LEDs draw very little power compared to halogens, and because car computer systems are designed to recognize stock halogen bulbs, an LED bulb may trigger an error. Some vehicles operate their headlights at a lower voltage to act as a daytime running light (DRL) and if you’re using aftermarket HID or LED headlight bulbs this can cause an issue. To fix LEDs flickering, one option it to install special CANBUS adapters, voltage boosters or resistors. If the car uses PWM to operate the DRL then the adapter is designed to smooth out the wave and provide a constant voltage to the LED. The other approach is to use LED bulbs that are designed to work with CANBUS equipped vehicles or T2 LED bulbs that operate correctly even at voltages as low as 6 volts.
The approach I took was to replace the halogen bulbs with CANBUS friendly LED lights as well as disabling the DRL setting and just running the headlights all the time.
But the final answer is, yes you can run LEDs as DRL if you get the right LED bulb. The bit I put in about not working in Canada is they have legal limits as to how bright DRLs can be and the above solutions run the high beams at full brightness.
