I've seen this thread discussed many times, but with no precise conclusion. So I'm gladly sharing some useful information I unwillingly got with my Abarth purchase.
TL;DR + Disclaimer
It is feasible, even from NA-spec to EU-spec. It will definitely void your warranty and enabling DRL may require some advanced electrical engineering skills.
For the brave ones, read further.
My NA-spec Abarth was initially equipped with halogen lights, but after a minor crash it was imported to Europe where both headlights were replaced with LED.
What works:
My DRL is currently wired through an additional relay they installed in the hood fuse box, so they disregard the CMU setting and are always on, but turn off whenever any other headlight is on (parking, low or high).
I'm absolutely happy with the outcome now.
Some video of the result:
TL;DR + Disclaimer
What works:
- Low Beam
- High Beam
- Parking lights — segmented halo is lit discreetly
- Auto lighting
- DRL (ignores CMU setting)
- No error messages on the cluster, none seen via OBD scanner, including proprietary ones.
- DRL setting in the CMU due to a custom wiring applied (see below)
- Adaptive lights and related functionality (lights aren't following the steering wheel and don't make a "calibration dance" when turned on). This requires a separate ECU which I don't have.
- Automatic leveling: possible in theory, but too much hassle to wire imho.
