1 - 5 of 5 Posts
Achieve quicker revs on your 1.4L Turbocharged FIAT by switching from your heavy OEM pulley to this lightweight pulley from SILA Concepts.
This pulley is designed to give your turbocharged FIAT a boost in performance by reducing rotating mass of the factory pulley. The stock factory pulley weighs 2.85lbs, the new replacement pulley weighs about a 1/3rd at only .95 lbs.
To get this lightweight pulley for your FIAT 124 please visit the link below:
FIAT Lightweight Pulley - Fits all 1.4L Multi Air Turbo Models (2016+) - 500 MADNESS - Auto Parts and Accessories
Discussion Starter #2
How to install? Check the website real quick and couldn’t spot it.
Discussion Starter #4
MiniDreamCar,
Thank you for reaching out to us about the installation of the Lightweight Pulley.
I does look like the installation information is not listed on the website.
Please let us do a little digging around the shop and see if we can get that information for you.
Thank you again.
Discussion Starter #5
Extensive weight savings were afforded by using aircraft aluminum for construction. Power gains are available as a result of this upgrade, but can vary depending on how your FIAT is set up.
We have been using these pulleys on our test vehicles for thousands of trouble free miles. We have also installed these pulleys on several track vehicles as part of our long term evaluations and they have performed without any issues.
For more information on the SILA Concepts Lightweight Pulley for your FIAT 124 please visit the link below:
1 - 5 of 5 Posts
