1 - 14 of 14 Posts
Take advantage of the thermal energy in your FIAT 124 and improve performance with the SILA Concepts Turbo Blanket.
We all know that heat soak will reduce power and performance but what if you could harness that energy and make it work for you. That is where the SILA Concepts Turbo Blanket comes in.
Once installed this turbo blanket will better contain the heat from the turbo manifold and away from other engine components. This has two benefits. First, by keeping that heat off other components you will increase their longevity. Second, by better containing that heat more thermal energy gets directed toward the turbine. Because hot gas fills more volume than cold gas this increase in thermal energy actually translate into a faster turbo spool!
More information can be found on our website
Titanium
https://shop.500madness.com/fiat-124-cid528/new-products-cid536/fiat-124-spider-thermal-blanket-titanium-pid4418
Red
https://shop.500madness.com/fiat-124-cid528/new-products-cid536/fiat-124-spider-thermal-blanket-red-silicone-fiberglass-outer-shell-pid4417
Black
https://shop.500madness.com/fiat-124-cid528/new-products-cid536/fiat-124-spider-thermal-blanket-black-silicone-fiberglass-pid4416
Let us know if you have any questions
Reduce under hood temps and improve performance with the SILA Concepts Thermal Blanket for your FIAT 124!
There is no easier way to protect under hood componenets, reduce temps, and improve performance with a single modification!
The SILA Concepts thermal blanket wraps around and hugs the turbo to keep all that energy directed at the turbine and out through the down pipe!
It also comes in three different colors!
Titanium
Red
Black
Discussion Starter #4
Reduce under hood temps with the SILA Concepts Thermal Blanket!
This is a really simple but effective modification!
Once installed the blanket will help to insulate the turbo and keep the exhaust heat directed at the turbines rather than radiating out into the engine bay. Heat is energy and with all that energy being directed at the turbine you will get an increase in turbo performance while also protecting other critical components!
Titanium
Black
Red
Discussion Starter #5
Discussion Starter #6
Installing a thermal blanket like this on your turbo charged vehicle is one of the most cost-effective power increasing modifications you can make.
Thermal turbo blanket from SILA Concepts is available in three color options:
Titanium
FIAT 124 Spider Thermal Blanket - Titanium - 500 MADNESS - Auto Parts and Accessories
Black
FIAT 124 Spider Thermal Blanket - Black Silicone/ Fiberglass - 500 MADNESS - Auto Parts and Accessories
Red
FIAT 124 Spider Thermal Blanket - Red Silicone/ Fiberglass Outer Shell - 500 MADNESS - Auto Parts and Accessories
I definitely will be buying one but unless the colors correction is way off in your pictures, I think you should rename your RED blanket to COPPER.
Just a suggestion - love the product!
Discussion Starter #8
Reduce the heat in the engine bay and boost the performance of your vehicle with this Thermal Turbo Blanket from SILA Concepts.
Decreased temperatures under the hood mean better radiator performance, cooler intake charges, and extended life for things like wire harnesses, fittings and vacuum lines.
To get this Titanium thermal blanket for your FIAT 124 please visit the link below:
Discussion Starter #9
Discussion Starter #10
Available in three different colors!
Titanium
Red
Black
Discussion Starter #11
Titanium
Red
Black
Discussion Starter #12
To view the full product details on this Thermal Blanket for your FIAT 124 please visit the link below:
Search - 124 thermal - 500 MADNESS - Auto Parts and Accessories
None of the links seem to work from my smart phone and I'm seeing essentially the same post over and over.
Discussion Starter #14
Hello AbarthEsq,
Thank you for reaching out to us.
We will have our IT Team look into what the issue could be that the links are not working for you.
Have you previously entered your vehicle information on our website? Sometimes the cache will keep your vehicle info saved which causes some hiccups with direct product links.
Are you using apple or android?
1 - 14 of 14 Posts
