21 - 40 of 42 Posts
Discussion Starter · #22 ·
Good on you. I melted down just before the pandemic so it ground everything down to a slow molasses drip right as the block was delivered to start work. Car was on stands for 11 months straight before I finally chained the transmission up to the body and rolled her out for a bath in September. I have changed everything short of the transmission, differential, and shafts. Those are all spec'd out and ready to order once I replenish my slush fund. The only stock part left will be the main body once I am through.
Wow! Now that's a mod. I've been watching F1 on Netflix and that gets me pumped to track this beaut.
Post some picks as well.
Discussion Starter · #23 ·
Out of that laundry list of mods the only one that might need additional attention is the rear Wilwood brakes. Beware that the emergency brake function is minimal to none. This is the consensus of many members on this forum using them. Other than that great build. Waiting for pictures and impression.
Dan
Yes, my mechanic told me not to use it for a while (like 300-500km) then engage it lightly, working it in.
The entire process is in my build post Going All In! Engine porn everywhere, its disgusting!
That isn’t the issue. I’m not trying to rain on your parade. I just want to make sure that you are aware of a potential safety issue. The ebrake mechanism is ineffective. There isn’t sufficient clamping power to hold the car On any grade. Brian Goodwin mentions this on his website. Make sure to park your car in gear. 👍
Dan
2018 124 Abarth
Hi Folks,
So as I live in Ontario, Canada, there are not too many FIAT mechanic specialists so I took it to a local place that works on toy cars/hot rods. Boy was I amazed! RPM Automotive, in Cambridge ON RPM Automotive | Auto Repairs in Cambridge, Ontario did a phenomenal job! I took it them because a) they are local so if I need any tune-ups, they are there for me and b) I wanted them to learn the car inside out with all my mods so they can help others, giving future clients confidence that they are more than capable of doing these kinds of things. They are a dedicated crew, meticulous and take a lot of care and pride in their work!
So the car will be ready today and I'll follow up with some pictures shortly. In the meantime, here is a list of what they installed for me (parts shipped in from US via Madness500, Good-Win Racing, MOPAR, CravenSpeed:
@MADNESS Autoworks @Good-Win Racing @Mopar @cravenspeed
FIAT 124 Spider MAXFlow Instake System - Wrinkle Black Finish
https://500madness.com/20g19-FIAT%20124-Lusso/fiat-124-spider-maxflow-intake-system-wrinkle-black-finish-pid4426
FIAT 124 Spider Thermal Blanket
FIAT 124 Spider Thermal Blanket - Titanium
FIAT 124 Ignition Coil MaxFire
FIAT 124 Ignition Coil Pack Set - MAXFire High Performance - 500 MADNESS - Auto Parts and Accessories
FIAT 124 Diverter Valve by Go Fast Bits / GFB-DV+
FIAT 124 Diverter Valve by Go Fast Bits / GFB - DV+
FIAT 124 Complete Under Body Ultra Light Brace Kit - Four Piece
FIAT 124 Complete Under Body Ultra Light Aluminum Brace Kit - Four Piece
FIAT 124 Rear Upper Tower Shock Brace
Do not buy these, they are the wrong fit! FIAT 124 Adjustable End Link by V-Maxx (2 sets for front and back)
FIAT 124 Adjustable End Link Kit - by V-Maxx
I have to order the right ones and it will be installed then.
FIAT 124 Ultralight Rear 4 Piston Caliper Upgrade - Black Finish (Willwood, Drilled and Slotted Rotor; Willwood)
FAIT 124 Willwood Dynalite Front Big Brake Kit - Drilled and Slotted Rotor - Black Finish
FIAT 124 Wilwood Dynalite Front Big Brake Brake Kit - Black/ Drilled and Slotted Rotor
FIAT 124 Front Sway Bar by Cusco
FIAT 124 Spider Front Sway Bar by Cusco
FIAT 124 Spider Rear Sway Bar by Cusco
FIAT 124 Spider Coilover set by Cusco - Street Zero A w/ Pillowball Top Mounts
FIAT 124 Spider Coilover Set by Cusco - Street Zero A w/ Pillowball Top Mounts
FIAT 500 Spark Plugs (good for 124)-Laser Iridium - NGK set of 4 - 1.4L
FIAT 500 Spark Plugs - Laser Iridium - NGK - set of 4 - 1.4L Multi Air Turbo (500madness.com)
System One Exhaust Package with Helmholtz Resonator
'System One' is a unique ADJUSTABLE SOUND Muffler/Midpipe Combo! Emissions Legal in ALL 50 States! for Fiat-124 , all
Cobalt Hood Lift Kit (Fits 124 Spider)
Cobalt Hood Lift Kit for MX5-ND
Authentic MOPAR Strut Tower Brace
Authentic Mopar Strut Tower Brace - 68328771AA | Mopar Online Parts
You will need Cowel if your 124 is not an Abarth:
2019 FIAT 124 Spider Strut Tower Brace Installation Kit - Cowel
Authentic Mopar Strut Tower Brace Installation Kit - 68330533AA | Mopar Online Parts
225/45R17 x 4 Michelin Pilot Sport A/S 3+
https://www.michelin.ca/en/tires/pilot/pilot-sport-a-s-3-plus.html
Fit search: https://www.michelin.ca/en/tires/pilot/pilot-sport-a-s-3-plus.html#tireVersions
DAI Wheels: Nerve DW110; Size: 17 x 7.5; Bolt Pattern: 4x100; ET: +40 (offset); Black Gloss
DAI WHEELS // Alloy wheels, Mags
Now I have a list of other items that I purchased for interior/exterior that I will install myself:
Seat Belt Shoulder Pads - Set of 2 (FIAT Logo)
Seat Belt Shoulder Pads - set of 2 - FIAT Logo
FIAT 124 Sun Shade / Reflector - Ultimate w/ Rain Sensor
https://500madness.com/2019-FIAT 124-Lusso/fiat-124-sun-shade-reflector-ultimate-reflector-w-rain-sensor-pid4279
FIAT 124 Auto Flash by MADNESS
https://500madness.com/2019-FIAT 124-Lusso/fiat-124-spider-autoflash-by-madness-pid4112
KIWI 3 OBDII Adaptor-Scanner, Dyno and Data Logging-Bluetooth
KIWI 3 OBDII Adapter - Scanner, Dyno and Data Logging - Bluetooth (500madness.com)
FIAT 124 Floor Liner Set - All Weather Leatherette - Black w/ Black Stitching - Deluxe
Stubby Antenna
The Original Stubby Antenna for 2017-2021 Fiat 124 Spider
Gemini Device Mount for FIAT 124 - Flex
Gemini Device Mount for Fiat 124 (2017-2019) Flex
Door Bushings for FIAT 124
Door Bushings for Fiat 124
Jam Handle for FIAT 124
Jam Handle for Fiat
Chimex for FIAT 124
Chimex for Fiat
Authentic MOPAR Roadside Safety Kit
Authentic Mopar Roadside Safety Kit - 82212566 | Mopar Online Parts
Authentic MOPAR Car Cover Black w/ Spider Logo
Authentic Mopar Car Cover Black W/ Spider Logo - 82215016 | Mopar Online Parts
Authentic MOPAR Emblem
Authentic Mopar Emblem - 82215037 | Mopar Online Parts
Authentic MOPAR Car Cover Grey Outdoor
Authentic Mopar Car Cover Grey Outdoor - 82215035 | Mopar Online Parts
Authentic MOPAR Windscreen
Authentic Mopar Windscreen - 68307694AA | Mopar Online Parts
Authentic MOPAR Splash Guards
https://www.moparonlineparts.com/sku/82215022.html
Authentic MOPAR Valve Stem Caps Black w/ FIAT Logo
https://www.moparonlineparts.com/sku/82213717ab.html
Authentic MOPAR Front Pillar Bar Bezel Piano Black
https://www.moparonlineparts.com/sku/68328781aa.html
Authentic Mopar Seat Back Pillar Bar Bezels Piano Black
Authentic Mopar Seat Back Pillar Bar Bezels Piano Black - 68328782AA | Mopar Online Parts
Authentic MOPAR Pedal Cover Footrest
https://www.moparonlineparts.com/sku/68307706aa.html
Authentic MOPAR Pedal Cover Kit Automatic
https://www.moparonlineparts.com/sku/68307703aa.html
iJDMTOY Smoked Lens Dynamic Sequential Blink/Flow Amber LED Front Side Marker Light Kit Compatible With 2016-up Mazda MX-5, 2009-2012 Mazda RX-8, 2017-up Fiat 124 Spider, Replace OEM Sidemarker Lamps
https://www.amazon.ca/iJDMTOY-Sequential-Compatible-2009-2012-Sidemarker/dp/B081ZGKXGM/ref=pd_ys_c_rfy_rp_m_289_0?_encoding=UTF8&pd_rd_i=B081ZGKXGM&pd_rd_r=R7TBPET0T49BJVD0G20M&pd_rd_w=jtYRV&pd_rd_wg=5nETP&pf_rd_p=f38ae268-7bc8-45f4-a6fa-2b7cd2e7c8e6&pf_rd_r=R7TBPET0T49BJVD0G20M&psc=1&refRID=R4S7CGMQR5XSY5Q1KA8H
This part is on back order so I have not installed yet but will once it arrives:
EUROCOMPULSION OIL CATCH CAN KIT (FIAT 124 SPIDER/ABARTH)
EUROCOMPULSION OIL CATCH CAN KIT (FIAT 124 SPIDER/ABARTH) (shopeurocompulsion.net)
So, I will follow up and post some pictures in the coming days/weeks.
WOW!!! This is going to be one fantastic car to drive. Wishing you all the best with it.
2017 124 Spider Lusso Stock
Nice post. There are a lot of products in here that I will consider and Cambridge is actually not that far away!
Discussion Starter · #29 ·
Dan
Ah, ok. I have an automatic so I'm ok. But I guess for manuals, they should be advised.
Thanks for the info.
One of the sacrifices we make for mods :)
On track, we don't use parking brake anyway.
Discussion Starter · #31 ·
Cool! If you want to meet up (in a safe way) for a cruise, let me know. Kinda bored here with no Fiat Club running because of pandemic.
I’ll keep an eye out for you when I can start driving through Ontario a game. 401 to 403 to QEW (cutting through Hamilton) when in your area.
Reactions: Fortuna
Discussion Starter · #33 · (Edited)
Gary, Sheila and crew at RPM Automotive are amazing! they took all my parts and installed them so meticulously and with a lot of car. I was so happy with their workmanship.
If you're in the area, shoot me a note and we'll go for a cruise if you'd like.
Just picked up Fortuna (that is her name). As I have to wear in the brakes and let the turbo blanket wear in, it will take a few 100 kms before I really push it.
Blanket is naturally smoking which is normal.
Brakes make a huge difference as well.
Everybody smokes in California, but that's a different story. 🤣 🤣
Can't tell if there is any point to the FIAT 124 Spider AutoFlash by MADNESS if you have a manual?
This is a lot of mods in terms of volume, but it doesn't look like anything particularly complex or dangerous. Proven suspension upgrades, some intake and exhaust improvements and no tune or engine mods other than the one above?
Discussion Starter · #36 · (Edited)
Some more pics: (can only post 10 at a time)
Shelf insert, Seat belt pads, front windshield in piano black finish (was silver), blue push start button cover, picture above side profile: look deep and you will see cusco front sway bar, car dropped with cusco coilovers, close-up air intake,
84813
84814
84815
84817
84818
84819
84820
84821
84822
Eurocompulsion Oil Catch Can with strut tower bar and cusco adjusters popping through:
84816
Discussion Starter · #37 · (Edited)
Screen cover, to cover the sun (works ok):
84824
Magnetic phone holder (Gemini) from CravenSpeed: Holds pretty good. I have a Pitaka magnetic case that also allows me to charge through it for wireless charge (for my other car). I like this one because it is less intrusive and places the phone right at my finger tips:
84825
side marker black-out lights with sequential orange blink:
84830
vibration reducers at door jamb (cravenspeed):
84826
124 Spider decal at grille:
84827
Mopar Foot pedal set:
84823
Discussion Starter · #38 ·
I still need to install floor mats and I ordered new adjustable end links from @Good-Win Racing. Once those are installed, I think I'm done for now.
I also need to install the rear wind deflector glass between the headrests as it requires drilling. MOPAR did not include a manual, just drill hole template. So I was thinking I would engrave the mechanics logo along with all parts/suppliers on it to give some props! Just need to follow up and ask permission from all if I can do so (RPM Automotive, Good-win Racing, 500Madness, CravenSpeed, Cusco, Mopar, Willwood, etc.)
nicely done. i installed the catchcan in the same place, but i really don't like it there. tough to unthread and check. I'm fixin to put it up near the radiator and pre filter on the V4 intake but i cant be arsed enough to modify the bracket to work there. really want to shorten those hoses and also make can maintenance easier
Discussion Starter · #40 ·
Sounds like a good idea.
I'll run with this install for now and see what it "catches" and should it work well, I'll leave it. If my mechanic checks it and if it doesn't seem to work well in its current place, I'll suggest what you are doing and see if that works better for catching oil and ease of maintenance.
21 - 40 of 42 Posts
