1 - 12 of 12 Posts
Due cento cavali !!!:eek:
Details please
What is that exhaust, it looks like you still have a rear back box of some sort
Sounds great! What exhaust is that? What else have you done to the car?
Reactions: rocklogic
2017, Fiat Spider 124, Abarth
We spent a week on those roads last summer...must be so much fun with that car. And yes, what is the exhaust system?
Discussion Starter · #6 · (Edited)
For all:
Ty for your compliments!
The exhaust is the stok exhaust (Record Monza) BUT i changed the catalyst:
The stok has 800 cell and now is more "open" whit only 200 cell.
This mean more gas velocity thru the catalyst and a lot of loud sound like a V8!
Attention: if changed it,. you must remapping the unit.
Bye!
Sounds great, and that sports cat makes it sound good!
I see the traction control light come on in 3rd and 4th gear. Are you really producing enough power to break traction at those speeds?
A few more questions
Was your that 200 cell downpipe a special 124 item or was a modified A500 item ??
Do you get any Check Engine warning lights
And who did your re-mapping in Italy ??
Discussion Starter · #11 ·
:laugh:
Yes, is all true.
Isn't a electronic problem or something about...
Don't forget that on 124 Spider rear axle there is a weight of only 550 kg (1200 lb)
More, the stock tires aren't enought wide for a good grip with about 200 cv.
Then, yes, what you saw, it's all true!;)
Discussion Starter · #12 ·
No isn't a A500 item modified.
Is a hand-made from a s body of a 200-cell catalyst where they welded the fittings fit to 124 and re-inserted into its shell and put in place
In the video there is the link of producer.
No, they istalled something that cheat the sensor.
In the video there is the link of "remappator."
Sorry for my english!!!!
1 - 12 of 12 Posts
