1 - 5 of 5 Posts
Any ideas on what or where this leak is coming from it is under the center of the car about one foot behind front tires?
The dealer had to replace the thermostat at 1000 miles.
Thanks
Thanks
It is certainly coolant. The coolant tank overflow is on the drivers side next to the strut tower. It dumps straight down into the belly pan and likely drained out behind the tire.
The system could have been overfilled a bit when they replaced the thermostat. I would check the coolant level and look for obvious leaks, if everything looks good, keep an eye on it and your temps. I wouldn't worry about it unless it happens again.
Reactions: Roadscum
1 - 5 of 5 Posts
