1 - 20 of 20 Posts
Hi guys,
I turned my previous fledgling thread on GPS nav into a full article, complete with a video tutorial on how to use the "Toolbox" software to update your maps.
Note, most recent map update is dated Feb 2018.
http://www.billavista.com/spider/Articles/Nav/index.html
Bill
Anyone manage to get the traffic function working? I imagine that connecting it to a wi-fi hotspot (like a cell phone) would give it access but whenever I tried to connect to my Android's hotspot I get "Network error" which is odd. I'll play with it further when I get a chance.
Mine has the factory Nav system and real time traffic refuses to work.
Well for real time traffic to work it will require internet access somehow. Unless there's a SIM card option in the system like OnStar has for example, I'm almost sure it needs to connect to either a Wi-Fi, blutooth or USB Internet hotspot.
That's where I fail. I haven't tried using an "open" hotspot - it may be that it simply doesn't support WPA2. The Nintendo Wii and Gameboy DS only supported WEP encryption until recently.
In one place, it says that it only works on radios with SiriusXM option, in another place it says the traffic information is derived from a signal in the HD FM Radio receiver, but then I found this:
https://www.carcomplaints.com/news/2017/mazda-connect-live-traffic-lawsuit-alerts-dont-work.shtml
So it may be that it doesn't work at all, and never has. It appears that "Historical data" would be embedded in the map software itself and updated annually... At some point it was a separate app in the "Apps" section of the radio (see photo) but that doesn't appear to be the case any more?
I never really noticed.
Also - although the hacks allow you to enable the WiFi, there doesn't appear to be anything that it's used for.
To use Live Traffic you have to set up your mobile/cell phone to be a WiFi Hotspot, and connect the car's WiFi to it. Live Traffic uses your mobile/cell phone data connection. I've not used it often enough to find the most efficient way to quickly enable the Hotspot, other than leaving it on all the time. Would be nice if it would use Bluetooth instead, but maybe it's too complex to be streaming music or a voice call at the ame time as sending traffic information?
I did a bit of research on traffic information through the TTN channel (HD radio) and the radio needs to be tuned into one of the channels that provide the information for it to work.
Essentially if you live outside of a few large cities like Toronto or Vancouver - there are none in Montreal although some channels will send information on the screen like weather, gas price advisory (wild in the Montreal region, up to 1.45$/l for regular :eek: ) and what show is currently playing.
I haven't checked the US market but I expect the same results to apply, so if you live in a big city you should be able to get traffic through that extra channel, otherwise wi-fi hotspot if you can get it to connect to your phone.
2017 FIAT 124 Spider Abarth
I got my map sd card on eBay for about $80. The update was fiddly but did work and the nav in the car works fine. I discovered you can use the voice command button to enter an address. Just say “navigate to new address” or something similar and the system will prompt you to say the full address. Seems to work fine so far.
I just bought a 2018 Classica with the Technology Group so the NAV function is available, I just need the (correct) SD card. This is an old thread and all the links to the proper SD card are no longer valid.
Does anyone have a current link to purchase the current SD NAV card?
Thanks
Kris
Thanks
Kris
Do you want a nav card that you'll be able to update content on after you buy it, or a version that's static (functional, but what you get for nav data is what you're stuck with for perpetuity)?
If you want the inexpensive version that can't be updated, just search for recent threads from the past couple of months and there's a link to one seller of those.
If you want a card that will be recognized as legit by NaviExtras and enable you to download new content, you need to purchase that through your local dealership at about 10X the cost of the version that can't be updated. Do not attempt to purchase a Mazda nav card as they will not function in our cars.
In short, you can have cheap or you can have updatable... but you can't have both.
Reactions: SteveP.
Thanks for the simple and concise answer. Just a follow-up question:
If one goes cheap now with the cloned SD card, will they be able to use a (expensive) legit card later? Or, is the NAV unit forever locked to the cloned card?
Oops I lied, I thought of another question:
How expensive are the updates for the legit cards?
1 - 20 of 20 Posts
