1 - 6 of 6 Posts
Hi,
New Spider owner just got his car last week are has done first modifications immediately (Thanks Greg). Nero Black Lusso version, black interior, V1 intake, AFE dry version and DV+ already inside. After wintertime I will look do I install Eibach suspension package and Eibach spacers to car. Usually we have about 50 cm snow here so some "real test" is needed before lowering car : )
With some degrees below 0 celsius not any issues have been seen yet.
Winterspider
Don't know if you have the same tires as the US, but might want to consider upgrading those for the conditions you are expecting to drive in. The US 3-season tires, in the snow, basically are only good enough to act as spacers between the rim and the road...
Congrats on your new Spider and welcome to the forum!
Thanks, have been reading forum since February, when I ordered this car.
Attached some info of tires, that I am using in wintertime. Grip will be not usually issue, but clearance between tire and fender. In some days new snow will be like glued inside fender and when it frozen to there it creates issues. That is why I will test this before lowering car. https://www.nokiantires.com/winter-tires/nokian-hakkapeliitta-8/
Winterspider
Reactions: Codyroo
Congrats and welcome.
1 - 6 of 6 Posts
