1 - 13 of 13 Posts
I am looking for a OBD II tool. Originally all I was looking for was a hand held reader that plugs in to the port and reads the codes if I get CEL light and can turn off the light. I read Ameridans article on readers that are Wi-FI and Bluetooth and I am looking for feed back on which is the way to go, a simple hand held or a Wi-fi/Bluetooth. Any recommendations on both types would be appreciated. Thanks in advance.
Bill B.
I have a Bosch OBD1050 bluetooth reader which connects to a dedicated iOS app. Purchased from one of the auto stores because I needed it in a hurry. I think it was $100; pricey compared to most others. I've been happy with it.
I bought a couple of those and downloaded the Torque APP, and works great. I left the OBDII connected to the car.
Works great
Frank...doesn't that run
Works great
Down the battery??? Did you ever get around to fixing that seat belt cover for me??
LOL
Not Sure:D:D
Another thing...I don't look at women from the top down...I start from the middle front, and make a fast circle around..>:)>:)>:)LOL:D:D:D
Discussion Starter · #8 ·
I've ordered a ELM327 and it's due Friday. Researching apps, I've found the Torque seems to work good with Android OS but not so good reviews for iOS so I am thinking of downloading the DashCommand app. Just for info purposes to anyone thinking about a similar set up, I'll report back once I'm up and running the tool. Any input is appreciated.
I wrote an article a while back on my ODBII experience that might be helpful. The port is hot, so don't leave your reader plugged in unless you install a switch, which I cover in the article, as you will end up with a dead battery after a few days.
Discussion Starter · #10 ·
I read your article and I thank you for the work you put in to this forum. I hope my research is correct. I wanted Torque Pro but reviews I read says it doesn't work that well with iOS, so that is why I'm going with DashCommand. And I ordered a cable with a switch.
Next project is installing your infotainment tweaks.
I have a spare decommissioned android and apple phone in thinking of using as a dedicated monitor. Would love to dig into this a bit more to have the reader switched on/off with the ignition.
did this last night. Elm327 ordered and dash command downloaded.
1 - 13 of 13 Posts
