1 - 20 of 27 Posts
Fixed - See below...
Today I was doing the Android Auto firmware upgrade per 68wooly's and ameridan's information.
Started with version 56 w/tweaks....Removed the speedometer as advised in the instructions.
Installed the ID7 tweak - no issues
Installed the 70.000.100A as instructed - no issues - everything worked
Installed the MazdaToFiatV70AIO as instructed - all good
Went to install a couple of original tweaks using ameridan's All In One Tweaks V1.5 - look good, but...
It hung on reboot...stuck at the Abarth logo....I've tried reloading the tweaks and removing the tweaks - no good.
Disconnecting the battery for a bit, let it boot to the main screen, and somethings work but not all.
Tried going back to reinstall 70, but the music, mute, favorite buttons don't bring up the Diagnostic Test screen.
So stuck. Ideas?
UPDATE 10/17/20 - Problem solved. Just needed a new CMU from eBay for $125...:(
Unfortunately it is a rev 59. .563, but the stock stuff works, until I can get back to this.
Try a hard reset - hold down Nav, Mute and Back for around 10 seconds - until the screen goes dark and the reboot starts.
Discussion Starter #3 (Edited)
Tried before, just tried again. No luck. Reboots, gets stuck at the Abarth logo at start up...
Discussion Starter #4
Everything was good and working, until I added a couple of tweaks using ameridan's All In One Tweaks V1.5.
Tried to go back and remove the ones I added, not sure if I got them all.
Both the MazdaToFiatV70AIO tweak, and the All in One Tweaks will load and work, but I can't seem to fix the issue with bootup. (Occasionally it will finish the boot, but some functions still lock up)
I suspect I need to reinstall version 70, but the diagnostic test screen won't come up to initiat that.
Discussion Starter #5 (Edited)
EDIT#2 - Not fixed....see below....
Got it....Back with an update in a bit.
EDIT: So I went back and methodically removed every tweak I may have made with the older DOS All in One Tweaks. Than I reran the MazdaToFiatV70AIO tweaks. After that everything went back to normal. I could even get to the Diagnostic Tech screen.
After all that, I used the newer MZD all in one tweaks installer for the background and a few other things.
Went for a quick drive....All appears well. Just need to order the hardware for the Android Auto finish....
I'm pretty sure the instructions advise against using my tweaks with version 70. Trezdog rewrote the tweaks to install in a different folder, because AA and carplay fill up the folder that tweaks were previously installed in.
Discussion Starter #7
Yes, you are correct. I just had the older version already here on my laptop, and used it without remembering everything I had read. Didn't realize until I went back to one of the many instructions I was using. (It really is hard to sort out the best, newest, and specific to one's situation instructions. Spent hours looking at all the info, and still screwed up).
So yes, my fault. No complaints. It's fixed and all good. Although I will admit to a little panic....LOL..
Thanks to you and everyone involved that made it possible.:)
Discussion Starter #8
Would there be any reason to go back and re-install Version 70 again?
Everything seems to be working OK, but I can't say for certain I've corrected all the files I mismanaged.
Discussion Starter #10 (Edited)
OK....Not fixed and back to where I started. :unsure:
Everything was working as it should. Did the hardware upgrade a couple days ago...
Android Auto worked as expect. All good.
Today I just added the Speedometer using the latest MZD-aio, and the nav stopped working. Just a frozen map.
So I removed the Speedometer - And it wouldn't boot back up. Stuck at the Abarth logo.
Occasionally it would boot up, but always locked up a couple screens or commands in.
Tried removing all the MZD-aio tweaks - No improvement
Re-ran the MazdaToFiatV70AIO - No improvement
Figured I should just reinstall V70.00.100.
After several tries, I got to the home screen and got the update diagnostic keypad up.
I could input in numbers, but neither the enter button, nor clear button, seem to work.
So I couldn't get to the update menu.
Stuck....:confused:
EDIT: Made a slight correction, but pretty much still the same.
Discussion Starter #11
OK....still stuck and hoping someone could point me in a useful direction.
Went back and removed all the tweaks I could, 2 or 3 at a time, and finally got it to partially boot, sometimes. I can usually get to the home screen, sometimes I can open a menu, but it always locks up. Once I got to the radio screen, and manage to tune a station, so I have some music....But that's it.
I think I've done what I can, randomly removing and installing tweaks. I believe reflashing the 70 firmware, (or even older), would be the best approach, but I can't get to the diagnostic test screen to enter the upgrade mode.
Is it possible to do something through the serial port? Any other options?
@68wooley and @ameridan your thoughts would be appreciated. Thanks!
Bob T, I feel your pain, take the car for a drive, shut it off, a couple hours after, your tweaks should be working. I think when the car reboots, it does not do a full reboot it's after a couple hours or so, when you start it,
First no Mazda logo and everything looked good.
When you add a tweak and reboots the darn Mazda logo appears and then the Abarth.
Discussion Starter #13
We are way beyond that, my friend. I've done the whole lock the car, and walkaway thing many times. No change.
Anyway, I've got a used CMU arriving tomorrow.
If it works, and depending on what revision it is, we'll be starting over this weekend.
Isn t there a Checksum procedure to reset the cmu. Good luck
Not that I know of...
Bob, I goofed my infotaiment. I removed the Desclaimer M from tweat 1.51, it was getting on my verves that disclaimer on start boot where it flashes and and says I agree., Removing went ok, on reboot if froze on the Abarth Logo, I redid the remove of M disclaimer and I got the Apps. but when I pressed the App, nothing displaying and froze.
I went for a walk , started and just froze on the Abarth LOgo
on the Radio is working, but cannot access it
Bluetooth connect but no phone working, neighther Nav.
Now I am feeling your pain, How can I reset the tweaks to factory setting. tia
Except for boot screens and background images, I clearly stated that version 70 tweaks should be from the MZD-AIO, because home screens are different now to accommodate AA and CarPlay. How many times did we tell frank? :(
frank, try installing that tweak properly, as it may save you from starting over.
Ok, I may have misunderstood,
I may have misunderstood, I am not blaming you, but myself, So what tweak I have to install,
Start animation or nav or ??????
I installed the REMOVAL OF "NO MORE DISCLAIMER", and now everything is back to normal. Speedomer is there but not active, looks like I have to go for a drive to active it.
Tomorrow I'll remove the Disclaimer and background image"blank blak" Now I can go to sleep in peace.All was done in tweaks 2.86
From my experience, as long as any install was not fatally interrupted, you can recover by removing tweaks. If any install is interrupted - especially and particularly a firmware upgrade - then the likely only solution is to flash the EPROM: this is a hard core removal of the Entertainment system and is an absolute last resort to throwing it in the trash.
1 - 20 of 27 Posts
