1 - 12 of 12 Posts
I have the walk-away lock function turned on so if I shut off the engine, exit, shut the door and walk away from the car with the keyfob in my pocket it will lock the doors.
I want this to work because keyless ignition and entry is pointless if I have to take the fob out when I leave the car to lock the doors...
This feature works properly as long as I ONLY walk away from the car. I hear one beep to warn that the keyfob has left the car, and as I walk away a second beep is performed by the car as well as a clicking sound of the door solenoids locking.
No issues there...
... except if I open the trunk.
If I shut off the car, get out with the keyfob and close the door I hear that first beep.
Then I make my way to the back of the car and push the trunk open button, the trunk opens.
I close the trunk and walk away BUT THE DOORS DON'T LOCK.
But wait - there's more: SOMETIMES, it will lock the doors after I close the trunk - I hear the second beep and the yellow signal lamps manifest with the doors locking solenoid sound. It only manifests the lights if I open the trunk.
What am I doing wrong?
I can't see any extra or missing steps for when the car locks vs when it doesn't lock. (except the trunk.)
I noticed this first when I used the button in the car to open the trunk this one time, and the doors didn't lock.
I've only had my Abarth for about a week now, but I noticed the same issue. To avoid the issue, I walk to the rear of the car and wait for the double beep to indicate the doors locked and then I open the trunk. It seems to only take a few seconds, and as long as I remember to open the trunk after the double beep I haven't had an issue with the doors not locking as of yet.
I don't use the auto locking mechanism, but I don't have to take the key fob out of my pocket to lock the doors. I just push the black button on the door handle. That locks the doors. I then go and open the trunk (or I pressed the trunk release button in the car). When I close the trunk, the lights flash, and the doors remain locked.
Exactly. No need to take the key fob out even with the walkway feature disabled.
Be sure two beeps before opening trunk and 100% reliable.
Reactions: Lord_GalAthon
I have the exact same issue. It's most annoying when I walk around the car to the passenger side to get my backpack, or anything, the car has locked already. Other times, I get out and walk away and it won't lock. I'm now in the habit of pressing the black button on the handle when I exit the car.
Yeah, I have several keyless cars so I use to touching the a spot on the handle. I would like the walk away feature if it had a timer that locked, say after 5-15 minutes. Now it's just a PITA so I have it turned off.
Reactions: melandat
if i have a passenger in the car who is slower to get out and i have already exited and walked beyond the front or rear of the car before the passage door is closed the walkaway lock feature does not happen.
Discussion Starter · #10 ·
YES! Of course. I tested it last night and this morning - if I get out of the car and walk to about 10ft away the second beep comes and locks the doors. Then I go to the trunk and when I close the trunk the car remains locked.
Thanks! That's what I was missing.
Discussion Starter · #11 ·
I've documented it in video because a lady on a Facebook group (weird people on facebook...) was being obstinate about ALL cars built in the last decade always automatically locking the doors when you walked away.
Like a Nissan Micra or a Mitsubishi Mirage will auto lock...
Anyhow, she's a car expert I guess.
1 - 12 of 12 Posts
