1 - 7 of 7 Posts
If you have an automatic...
Apparently stopping the engine while in Neutral rather than Park will keep your radio + USB ports on, and is probably the maneuver to remember when you wish to remain in the vehicle and continue listening to your radio/streaming audio, simply slipping it into Park after the engine has shutdown. Again, you’ll actually be in ACC mode rather than in OFF mode, and this gives you up to 25 minutes more time before the CMU turns itself off, but this can be extended by tapping the brake pedal once prior to that timeout, for another 25 minutes.
There's a socket in the passenger footwell, not sure if it's always live. You can also get an OBDII to USB dongle
The socket in the footwell is not live when the car is shut off.
2017 Abarth
skos005, to answer your question specifically, I recommend this, but remember if a USB adapter is plugged in all of the time, it will draw down your battery, so it should be unplugged from the 12-volt receptacle when not needed.
[...]You can also get an OBDII to USB dongle
Constant Power Cable | Garmin ...I have one, works well.
This can also be accomplished with the transmission selector lever in Park by holding its button down when tapping the start/stop button to turn off the engine.
1 - 7 of 7 Posts
