I'm ordering a 124 Abarth but haven't driven one yet. Would you give more detailed impression of the ride quality (harshness, vibrations, rattles, road noise, etc.) now that the tires are set properly? Also, if you've driven a non-Abarth 124, how did the two models compare in ride quality?On my way home with my new Abarth, the suspension was so harsh that it was making me have second thoughts about my purchase. Of course, the tires were set at 49 psi. At 29 psi, it is now a much much nicer car!
I asked the same question earlier...found the answer in another thread....page 120 of the owner's manual explains how to initialize/reset the tire pressure monitor...How can you tell if the tire pressure monitoring is initialized?
Joe m, ck the tires when they are stone cold. Just FYIJust checked mine....49-50 psi in each tire. Glad the OP posted this.....thanks.
EDIT TO ADD: How can you tell if the pressure alarm was initialized?
They were as cold as they could be after sitting overnight....Joe m, ck the tires when they are stone cold. Just FYI
That's exactly what I had hoped to hear, thanks! Now back to the regular thread…OFF TOPIC, reply to Steven...
