Good evening ladies/gentleman/whatever,
this is a continued post from last year, where i said i would look into my motor/transmission because of different problems.
Just a quick sum-up:
-Im driving an Abarth 124 Spider Tourismo, build 02/2017, EU.
-Im not a car-mechanic, just a normal dude with no wife.
-Got it from a respectable second-hand-cardealer with 1 year warranty and good documentation. It had 12.000km on it. Price around 25k€.
-Problems were beginning after the warranty.
-Went to a official Abarth-Center for just changing all fluids and filters (you can read it in the post last year).
-They fucked up (2 spark-plugs not properly screwed in, had engine-failure after 3 weeks, cleaned spark plugs and ignition coils, then it worked. They also apparently threw away 5 screws of the plate below the oil-pan for no apparent reason. If the motor was damaged in this time its smth i had no time so far looking up, will do after my transmission is fixed. They got 1 star-rating, just for your information.
Now there were more problems this year, beginning february:
dual mass flywheel, because otherwise the transmission would constantly be noisy, not go quiet if you press the clutch (The rear-wheels would still spin the transmission, even with a
locking differential.
- And the biggest problem: i went to a car-mechanic to get it checked, they heard it when first started, they brought it on the lift and then: NOTHING. For the next 3 hours, they couldnt locate the noise and they wrote it off (And i did TÜV, didnt make it because my left front tire had a scar from when i had to evade a bicycle-driver, not that this is worth mentioning here). Not even 10 Minutes after i left with my car again there was the grinding noise again and yeah...worth paying.
Now, after many weekends where i told myself to do it next weekend because at some point you think everyone is just not taking the time for you to fix smth because you are worthless, i brought it up on the lift and got the transmission down. First of all:
-A: I dont have the right tools to properly work on the transmission. Yes i should have bought the right tools first and then start doing smth but i still got it as far as you can see on the photos.
-B: Working to get the Transmission out was a meticulouse, 6 hour deal, because of no room to navigate, no transmission-lift and secret screws where you have to build out nearly everything to even see them (Thanks to Huskky, BGS and whatever extension-brand helped me out here).
-C: I hope i get it build together properly, but the only thing that broke was a bolt below the Catalysator (Was heavy-screwed in, screwed back in, back out, sprayed it with creep, then back... and it broke). Will see that i get the correct screw for it, in the meantime...meh, whatever, some spit and glue will work out fine.
So as you can see i can cry quite good, even though i should know this is not easy.
Okay, now to the real matter:
After i got the transmission out the dual mass flywheel had Brass-chips on the center hub. After looking inside it i saw blueish spots on most of the inside, meaning it got very hot. The same on the clutch-disk at the center-points. (Photo 3 and 4)
While building down the transmission the actuator for the clutch return bearing was leaking a little, but only when being completly engaged. Now here is my first question:
- Does it leak when you take it off and it can completly actuate all the way? Maybe i did smth wrong and you should never do it, but just asking. (Photo 1)
Maybe the actuator never properly engaged the clutch and thats why i had problems with my clutch. But im guessing atm, i continue tomorrow.
Now for the second question:
-If i build it together again, with everything properly torqued down and new clutch-disc and dual mass flywheel and connecting all sensors, do i need to relearn the ecm or smth like that? Especially with the synchrogears?
Im pretty sure in this day and age you always have to reprogramm smth if you change it, but maybe this is not the case. Just for interest: before i disconnected anything i terrminated the minus on the battery, the more you know.
Third:
- Do you guys know what the tolerance of movement is on the gear-shaft? It is a little bit on the lean side and before i start making a mess out of it and playing in an area where i only know basic knowledge i better ask you if it can have some movement. Because if i have it already down, might as well make the best of it.
Fourth:
I uploaded all images, if someone can point out smth if he sees a defekt or mistake (except the black powder, normal abrasive material from the clutch) i gladly take the suggestion.
And last:
- Is there a good diagnostic-tool for relearning an abarth 124 spider without paying a 1000€ on it? I have an Autel here (~400€), but apparently it doesnt support the Spider. Only the 500, and if i Auto-VIN it it doesnt find it. (Already ask manufacturer, a sorry is the only thing i got). Maybe Mazda MX5 works? Does someone know which ECM is build in?)
Thanks for a reply and have a nice weekend.
With regard.
A bavarian guy.
- Had difficulty getting my gears to properly engage, mostly in first and second (The noise of grinding gears even though the clutch was completly pressed down was, to say the least, quite scary).
- Transmission had sometimes problems when going uphill, especially in first gear it would sometimes wobble and a rough start.
- When accelerating starting at 4000RPM every single time trying to engage from first to second even though the clutchstick was properly in there and i slowly let got of the clutch it threw moneyshots. There was around 2-3 times it went smoothly, but it pissed me off (Im a very....very emotional driver sometimes, sorry for having to be truthful)).
- The clutch, from first to thrid gear, would grind, with acceleration it got louder and went through the whole drive, sometimes there was nothing, sometimes you were scared that you have to call a taxi and get it towed back. BBehind the steering-wheel the armature was rattling a little.
- The Motor sounded unhappy when the grinding happens, as if he has to pull a trailer or smth (slow acceleration, small changes to RPM when in idle, sometimes the car was totally fine and no noise was heard).
Third:
Fourth:
And last:
With regard.
A bavarian guy.
