Try as I might, I could not find recommended points for jack stands under the 124 for the winter...
Other than "Not on the suspension, newbie", This is what I was able to come up with.
Any thought from others that are more familar with hoisting their cars off the ground for the winter?
Front is on the member to which the front A-arm mounting brackets are welded.
Rear I am unsure how to describe, but is an outboard cross-member directly beneath the suspension mounting bracket
Related: boy the car looks goofy at full droop with 3-4" clearance under the tires.
